09-04-2017, 06:51 PM | #15 |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
Sending all our thoughts and prayers to you guys going through all this. God Bless you.
And yes, you can run 87 just fine. The computers will adjust for it but if you drive the car normal I doubt you'd even notice any performance difference. |
09-04-2017, 06:54 PM | #16 | |
Don't trust anything not authorized by General Motors. |
09-04-2017, 08:41 PM | #17 |
Drives: 2020 2SS 1LE Join Date: Apr 2016
I'm in central Texas so we had some strong winds and rain, but NOTHING like the devastation along the coast. Many people lost everything. We r blessed here that we did not experience that. Thank u for ur thoughts and prayers for those affected. Glad I can run the 87 without worry.
09-04-2017, 09:10 PM | #18 |
Drives: A10 LT4 Join Date: Aug 2016
Weird...our gas issue started last week & I'm carrying around 10 extra gals for my company truck. I burn 35-40gals a day & cannot get in a situation to not get home.
Still, I had no problem finding 93 for the toy...all the 87 was gone over the weekend?? |
09-04-2017, 09:30 PM | #19 |
Drives: 16 2SS NPP MRC Join Date: Aug 2016
I'm the guy who drove 20 000km or 12000 miles on 87 octane with no issues. The car will drop your HP by a few but there will be no issues.
09-04-2017, 10:01 PM | #20 |
Drives: 2019 ZL-1 Join Date: Feb 2009
Corrosive additivies.
2012 Yukon XL Denali w/ 6.2 AWD |
09-04-2017, 10:06 PM | #21 |
The only octane booster worth buying is Torco...it's safe for o2 sensors and can turn 93 octane into true 107 octane race fuel. So you could bump 87 up to 93 octane easily but its not cheap. 25.00 for a 32 oz can.
2016 NFG 1SS A8
09-04-2017, 10:11 PM | #22 |
09-05-2017, 12:18 AM | #23 |
the computer can not pull enough timing to run 87 in it at full throttle. You will be fine to drive it like a prius. Just go back to 93 when they have it and stay out of the throttle. don't put snake oil additive in it.
09-05-2017, 02:58 AM | #24 |
Drives: 2016 Summit White 2SS Camaro Join Date: Aug 2016
I do not believe this to be true. I worked in the car rental industry for years and we only used 87 octane fuel in every car, no exceptions. Rental customers also do not buy premium fuel, and they drive those cars like they are stolen. 87 octane will do nothing to the car......unless there is some aftermarket tune on the vehicle that requires a high octane fuel.
09-05-2017, 03:59 AM | #25 |
Drives: Really Fast Join Date: Aug 2017
You can add toluene to raise octane. I make my own race gas. I buy toluene at the paint store in 5 gallon containers. You can add a max of 10% toluene. Toluene is 114 octane so do the math. Recipes can be found online.
09-05-2017, 09:38 AM | #26 |
GM even says a knocking may be heard. That is preignition and is doing damage to the pistons. It may take years for it to bore through a piston if you're not full throttle all the time. Every time you hear a knock its because the car can not pull enough timing and each knock is taking a small chip out of the piston.
from the manual For the LTG 2.0L L4 turbo or the LT1 6.2L V8 engines, premium unleaded gasoline meeting ASTM specification D4814 with a posted octane rating of 93 is highly recommended for best performance and fuel economy. Unleaded gasoline with an octane rated as low as 87 can be used. Using unleaded gasoline rated below 93 octane, however, will lead to reduced acceleration and fuel economy. If knocking occurs, use a gasoline rated at 93 octane as soon as possible, otherwise, the engine could be damaged. If heavy knocking is heard when using gasoline with a 93 octane rating, the engine needs service.
09-05-2017, 09:47 AM | #27 |
Drives: 2016 2SS, Red Hot, NPP, Nav, M6 Join Date: Jul 2016
I'm not sure I buy the comment of "every knock is taking a small chip out of the piston". Pre-detonation is the knock, it's a shock wave the mechanicals have to deal with, but not actually removing metal from a piston.
09-05-2017, 10:28 AM | #28 |
Drives: 2014 2SS/RS/1LE Join Date: Mar 2015
Unless you are running 11:1 compression or more than you can safely use regular gas. GM released a statement back in 2003 or 2004 about this. I just wouldn't run it hard and like others have said you will lose a few hp but that's about it. There is no need for an octane booster either.
