Old 06-16-2019, 12:55 PM   #1
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
Tps. UPDATED with part number
Update: Thanks to L78toLT1 for the tip! I got in contact with jms and they are going to be releasing this pigtail to be purchased on its own. For those not wanting to butcher factory wires it appears we have a p&p solution!
Part number: JMS-CA-105705-0-5V-adapter
I've searched and everyone says to get TPS signal from the pedal. How is everyone doing it? It's like a 3" little pigtail. Are you t-tapping? I'm not fond of those. It just looks too small to cut and solder to me.
Or is there an easy place to get it under hood? I thought I read you couldn't get it from the throttle body.
Any help would be appreciated
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 06-17-2019, 08:41 AM   #2
lokitwitch04
Drives: 2017 Camaro SS 2SS
I used the wires at the pedal. Its a PITA.
lokitwitch04 is offline   Reply With Quote
Old 06-17-2019, 08:11 PM   #3
L78toLT1
L78toLT1's Avatar
I purchased a jumper pigtail harness from JMS. Newer JMS voltage boosters apparently come with the pigtail harness but I had to purchase mine separately. I think it was around 30 bucks directly from JMS
Baby Blue
Old 06-17-2019, 08:16 PM   #4
Dubchitts
Dubchitts's Avatar
Perfect!!! I was actually thinking about contacting pedal Commander or vitesse and see if they would make a 1 off thing for me
Thank you both for responses.
"Spitfire" 427ci
Old 06-18-2019, 01:52 PM   #5
Dubchitts
Dubchitts's Avatar
Just spoke to jms. They will be generating a part number for just that pigtail! Once they email me that I'll post the part number and link in my first post
"Spitfire" 427ci
