11-18-2016, 08:01 AM | #57 | |
i will say one things for sure, it absolutely doesn't have the benefit in no lift shifting compared to the 4gen and coyote that didn't have the timing cut. at best its negligable, therefore not worth beating the driveline. talking to the wife about going to atco tonight as well. fraxum, those are good 60' times on stock rubber. im going to try a 2250rpm launch, lets see if i can grab a sub 2.0. Last edited by 6spdhyperblue; 11-18-2016 at 08:42 AM. |
11-18-2016, 08:15 AM | #58 |
im curious, at a track where youre not able to use 100% at any point in first gear, how are you supposed to slow the spinning using the LC 2step starting off at 4k?
if you go slow enough to get the right amount of wheel spin you have to be slow on the clutch to the point you will burn it, if you go quick where it wont burn it will roast the tires. after that event is over, the electronics throw you to 100% throttle and you're spinning too much anyway. so tell me again how LC trick is the end all be all? |
11-18-2016, 08:16 AM | #59 | |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
11-18-2016, 08:18 AM | #60 | |
マスタング = 遅い
I will be giving it a go when I get my car too... |
11-18-2016, 08:19 AM | #61 | |
when i say im not no-lift-shifting i am lifting slightly and confiming not initiating the timing cut as i am back to 100% power instantly. when the timings cut from no-lift-shift being initiated, its very obvious. i have used the LC trick. on a track. every time but once where i went all in on LC, it was a prepped surface, with the sun out, and it wheel hopped, which is not as common in this car at all. especially compared to a cayman(horrendous) and my 14 gt(shocking for a SRA?!?!?!). im anxious to go back and not try it. |
11-18-2016, 08:25 AM | #62 | |
マスタング = 遅い
11-18-2016, 08:31 AM | #63 |
the missing variable is that the LC should have an adjustable rpm window like in the mustang or any real 2step. that worked well. the rpm is what you're supposed to be adjusting to track conditions, usually not clutch engagement
11-18-2016, 09:08 AM | #64 | |
マスタング = 遅い
So in a perfect world, having both would be ideal. |
11-18-2016, 12:33 PM | #65 | |
Doesn't LC pull timing if you spin? My understanding was to launch on the verge of spinning. LC does sound like it could help as SS 1LE explained. I may try it next spring. I just don't want to rely on it. I did have less trouble before I did the boltons. That my car has more power up top means I can get past the lights if I launch easy. But the spinning starts at top third of first. The shift into second hard causes some spin, but not too bad. Even with all that, good runs that night were 12.3s for me. Maybe if conditions are not any better tonight I will short shift into second. And with the cold wave coming the run flats are going back on by Sunday. Your car if stock might do better on bad prep than my SS. Tonight will be bad I think. Tomorrow will be better for sure. But I may go just to watch old stockers tear up the track. How do they make those old muscle cars so fast being "almost" stock?
11-18-2016, 01:02 PM | #66 | |
Drives: 2016 1SS, 2017 JKU Wrangler Join Date: Mar 2016
SLO 1SS - sold
1SS MRC NPP 6MT 2018 Ram Rebel 4x4 5.7 |
11-18-2016, 01:09 PM | #67 |
11-18-2016, 01:37 PM | #68 |
gotta love internet racing
11-18-2016, 02:49 PM | #69 |
I do too. It's almost as much fun as the real thing. I enjoy a fender to fender race even more than just a faster run. That is why I have so much fun racing my friend Pat with apparently the fastest stock S550 auto GT in the nation. Even though my car is now a bit faster he is hard to beat all of the time. We raced to a draw last Tuesday. My best was 12.3 and his was 12.2. He ran that one early, as the air got better he was spinning too.
11-18-2016, 03:00 PM | #70 |
fraxum i dont think we've met. it takes me a bit over 2 hours to get down there with no traffic. i haven't left yet. im trying to wrap things up here.
edit: not gonna make it, the traffic on 287 or 95 is really bad. i will go one more time by next sunday. i have a wedding friday in marlboro and staying overnight so i might go saturday as its under 1.5 hours from there. dont know if youre free but ill keep you posted Last edited by 6spdhyperblue; 11-18-2016 at 03:56 PM. |
