03-17-2019, 10:03 AM | #15 | |
ARH and I had run multiple 20 minute sessions on the road track in the heat of TX summer at 680 rwhp. |
03-17-2019, 09:38 PM | #16 | |
Drives: 2018 Camaro ZL1 Join Date: Feb 2018
03-17-2019, 09:39 PM | #17 |
I think I'll give the kooks green a shot. I barely do long pulls, just 60-140ish pulls every once in a while. Thanks for the suggestion though. I have kinda swayed towards acceptance...lol.
03-18-2019, 08:39 AM | #18 |
Drives: 2017 Camaro ZL1 Join Date: Aug 2018
03-18-2019, 08:58 AM | #19 | |
03-18-2019, 12:10 PM | #20 | ||
Drives: 2016 CTS V Join Date: Feb 2012
With half mile and mile racing you will run a more rich AFR to keep cylinder temps down and hopefully prevent detonation to to high cylinder temps, in turn mean cooler exhaust temps as well. Again a better environment for the cats. |
03-18-2019, 04:55 PM | #21 | |
That's why COT (cat over-temp) protection mode makes the AFR rich(er), which creates lower temps in the cylinder/exhaust to protect the cats. |
03-18-2019, 07:17 PM | #22 |
Drives: 2023 ZLE Join Date: Jun 2009
Catalysts generally fail for one of two reasons. 1.) Excessive internal temperature due to uncontrolled combustion in the catalyst (generally from misfire). Multiple complete cyclinders of unburied air/fuel will drive temperatures up to extreme levels that will cause cordierite catalyst substrates to soften/melt. Metallic substrates may be more tolerant to this temperature but the catalyst wash coat will be damaged. There could be other events from aftermarket tuners, besides misfire, that cause events similar to misfire. 2.) Mechanincal failures due to vibrational accelerations experienced in the exhaust system while driving. Catalysts are ultimately connected to the engine and at high engine speeds, the exhaust can experience some significant vibrational input from the engine. The OEM spends a lot of time and money engineering and validating the factory exhaust system’s mechanical design and ultimately its durability. No way that aftermarket companies are undertaking this effort. I’ve got a little experience in this area. If I were going the aftermarket header and exhaust route, it is probably safest to not use their catalysts. It’s not technically legal either way, using the aftermarket catalysts or not, so it is safer to not (from a durability perspective) IMO.
03-18-2019, 07:28 PM | #23 |
Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
Just curious if any of this applies to the GESI Green cats since they're rated to handle way more than i'd imagine the stock cats.
03-18-2019, 07:32 PM | #24 |
I am not exactly sure. I went to a local Muffler shop and they installed whatever they had on hand. They appear to be non-branded bottle style resonators. The are 3in Inlet/Outlet and about 18in long and they and do help tremendously.
03-18-2019, 08:35 PM | #25 | ||
03-19-2019, 10:26 AM | #26 | |
This is just me personally, I have a hard time swallowing that the factory cat is so much more highly R&D'd over a company that specializes solely in producing performance products that exceed manufacturer specifications. Keep in mind GESI isn't just a name, it stands for "Global Emissions Systems, Inc". All they do is design, development, and manufacture emissions control products for the past 20+ years.. It wouldn't surprise me to learn that GM outsources the stock Cats to the lowest bidding supplier they can find with some sort of financial protection warranty for them in place if suddenly they all start failing. I highly doubt the stock cats are any competition with a GESI cats. Check these out: Vibrant Performance Part Specifications ---------------------------------------------------------- Inlet / Outlet: 3.00" Converter Body O.D. - 4.50" Overall Length: 7.00" Engine Limit Per Bank: 500-850HP Substrate Cell Count: 300 cells / inch^2 GESI High Output (HO-series) and Ultra High output (UHO-series) Universal Metal Core Catalytic Converters have been designed to provide a reliable solution to the most common converter problems experienced by our customers. - EPA certified for use on OBD2 vehicles (1996 and newer). 49 States only! - Full Stainless Steel construction, including the substrate which is furnace braised to the mantle for outstanding durability - Unique end-cap design locks substrate in so it can't rattle around - The GESI proprietary precious metal loading technology ensures greatly reduced emissions, eliminating most "Check Engine Light" issues - Capable of withstanding up to 1500 deg F - Ideal for forced induction applications, with no loss of HP - Covered by a 5 y https://youtu.be/56oLVgpwOAs I don't track my car and with as heavy as traffic is around me I'd be lucky if I can find a long empty on-Ramp that I can open it up on once in a while so I'd say 95% time I am not beating on it. I just want to reduce or eliminate the awful gas smell and if possible reduce the drone some. I am confident a company like Vibrant makes a quality product and even backs it up with a 5yr warranty that it'll just work out fine.
03-19-2019, 11:40 AM | #27 |
So I ended up NOT installing the kooks green and am currently having magnaflow 200 cell metallic cats installed. They actual look like they flow better than the kooks green (lower cell count and it even has a hole in the middle that goes straight through. It was so much cheaper and honestly, if they end up breaking, I'll just gut them and leave it like that. I don't even have rear O2's to worry about. I love the catted sound and lack of smell so I'll just give these a shot.
03-19-2019, 12:33 PM | #28 | |
I'm aware what GESI is... Please note, my entire post is my opinion based on experience and discussion on multiple forums...I don't like rasp/smell/obnoxious exhaust anymore than the next guy. And yet, I still would recommend catless, so that should tell you something. |
