05-25-2019, 02:32 PM | #1 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Cam Slam Weekend!!
More to come! #piginslop.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods Last edited by RobZL1; 06-07-2019 at 02:20 PM. |
05-25-2019, 05:48 PM | #2 |
ZL1 Pilot
Cool! Now get that strut bar out of the way. Lol
GP Tuning 2.5 Cam, RPS Carbon Twin Clutch, Ported Blower, Kook's Headers, Cold Air Inductions CAI, ID850's, 9.17 Lower, 2.5 Upper, JMS BAP, Pedders Front Radius Arm Inserts, Whiteline Subframe Inserts, Tuned by me with HP Tuners Idle Clip Link...........https://www.youtube.com/watch?v=gTL8S9eHwbs |
05-25-2019, 08:54 PM | #3 |
Those who need me got me
Drives: 2022 ZL1 A10 Join Date: Aug 2017
Congratulations
05-25-2019, 09:26 PM | #4 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
What cam specs did you go with?
05-25-2019, 11:18 PM | #5 |
fo'shizZL1
I'm probably in the minority, but I don't mind it. I can work around it without any issue.
Thank you!! I'm excited! I chose the GP Tuning 2.5 (same one as ABADZL1, actually). After a lot of research, I think this will best suit my needs. It's somewhat similar to a BTR 3. On another note, if anyone has any helpful tips on getting the wire tray loose from the side of the block or the side of the oil pan, I'm all ears. I got all of the oil pan bolts loose already with the help of a flex-head ratchet wrench. Then I realized the darn wire tray bracket-thing is actually bolted to both the oil pan and the block on both sides, and prevents the pan from dropping. All 4 of the bolts on the bracket are nearly impossible to get to unless I start pulling more stuff off and out of the way. That may be what I'll need to do, but thought I'd ask first before pulling everything off. Hopefully I'm just missing something.
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
05-25-2019, 11:22 PM | #6 |
fo'shizZL1
More photos of progress today.
Stock trunions pressed out, CHE trunions installed, oil pump ready to be removed as soon as I can get the pan out of the way to get to the pickup bolt.
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods Last edited by RobZL1; 06-07-2019 at 02:22 PM. |
05-26-2019, 11:41 AM | #7 |
Drives: 2014 Summit White ZL1 Join Date: Oct 2018
Looking good.
I just finished installing my GP Stage 2 Cam. By far, the hardest thing to do is the oil pan, I actually ended up getting a second set of hands to help push down the Oil Pan. I ended up not even removing Wire Loom Tray thingy, and just removed all the bolts with extensions and a universal joint. You will have to remove a nut/bolt on the passengers side, there is a black bracket that's attached to the oil pan that will prevent you from forcing the pan down. |
05-26-2019, 12:25 PM | #8 | |
fo'shizZL1
05-26-2019, 02:02 PM | #9 |
ZL1 Pilot
The wire tray has a nut threaded on to a stud on the driver side, front section of oil pan by the alternator. Both nut and stud need to come off. Some cars have one facing forward as well securing evaporator lines if i remember. I do so many of these on all year camaros i dont remeber which years are slightly differ.
The passenger side has a bolt stud attaching the wire tray just behind the a/c compressor on the side of the front of oil pan. Then you can wedge something in between the pan and block being careful not to scratch or damage the gasket.
05-26-2019, 06:58 PM | #10 |
fo'shizZL1
Now we're talkin'! Thanks for the details.
05-28-2019, 10:07 PM | #11 | |
fo'shizZL1
It lives again!
05-29-2019, 06:08 AM | #12 |
Drives: 2012 ZL1 Ashen Grey Join Date: Apr 2017
Very nice. Isn’t it the best sound!! It’s like a brand new car! What’s up with the exhaust tips?
2012 M6
Kooks 1 7/8, off road pipes , full corsa exhaust ID1300s/ 22% lower / 2.5 upper, JLT CAI, DSX flex fuel, DSX AUX fuel pump. S19 cam Tuned and built by Speed Inc 635/632-93 octane 725/738-E85 |
05-29-2019, 11:56 AM | #13 | |
fo'shizZL1
Regarding the tips, I assume you mean the nice patina from a lack of cleaning in a really long time? Otherwise, it's just the stock tips.
05-29-2019, 03:14 PM | #14 |
Patina!! Love it. Get u some corsa!! You’ll love it!!
2012 M6
