04-05-2017, 09:12 PM | #1 |
Drives: 2018 Camaro ZL1 Join Date: Jun 2011
Okay to run Z/28 Diff without Cooler?
I'm in the middle of putting in a Z/28 rear diff and am wondering if it's okay to run it with the cooler lines capped off?
04-05-2017, 09:31 PM | #2 |
Depends on how hard you drive it I think since the car is setup to be a track car. You can buy the cooler kit for a SS so not 100% sure it's required for a DD non track car.
Orange Krush II
04-05-2017, 09:35 PM | #3 | |
I might add the cooler in the future. I don't do any serious track time, mostly just autocross so I'm not worried about heat so much. Just wanting to make sure running with the fittings capped won't hurt anything. Sent from my iPhone using Tapatalk
04-05-2017, 09:37 PM | #4 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
No prob running without it. It is nice to have if you track the crap out of the car.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
04-05-2017, 09:40 PM | #5 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Thought the Z28 had the same diff as an SS but better carrier?
04-05-2017, 10:35 PM | #6 |
Isn't the Z/28 helical?
04-06-2017, 08:14 AM | #7 |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
IIRC... it's an SS housing with the Torsen carrier (similar to the Eaton Truetrac) and a cover mounted cooler. It also has 3.91 gears like the 1LE.
Sent from my SM-G935V using Tapatalk
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
04-06-2017, 12:41 PM | #8 | |
It is a Torsen. Externally the case looks the same as my SS. The cover has inlet and outlet fittings to connect to an external cooler. Sent from my iPhone using Tapatalk
04-06-2017, 01:42 PM | #9 | |
04-06-2017, 01:47 PM | #10 |
I thought the Z28 case was heavier still aluminum but heavier???
Orange Krush II
04-06-2017, 10:27 PM | #11 |
I've decided no problem running with the fittings capped. The lines carry transmission oil through the heat exchanger in the diff cover. No diff oil leaves the diff.
04-07-2017, 06:43 AM | #12 | |
This is why I'm going to do an Eaton Truetrac with Billet caps and a LPW cover. If I need a cooler I'll figure something out later. Sent from my SM-G935V using Tapatalk
