02-25-2017, 04:41 PM | #1 |
Drives: 2018 Camaro ZL1 Join Date: Jun 2011
SOLD! FS: Pfadt ZL-Spec Sway Bars
SOLD! For sale Pfadt ZL-Spec Sway Bars. $400.00 for the set. Shipped from Utah
02-25-2017, 10:39 PM | #2 |
What size are they?
Orange Krush II
02-25-2017, 10:44 PM | #3 |
They are hollow chromollly so I'm not sure the diameter would make sense compared to a solid bar. Here's a link I found that shows data about them
http://www.phastekperformance.com/20...l1-1410138.htm Hope that helps.
02-25-2017, 11:01 PM | #4 |
Drives: 2013 ZL1 416 Join Date: Feb 2013
i guess these dont work on 2013 zl1 electric rack
02-26-2017, 08:57 AM | #5 |
Drives: 2010 Camaro SS Join Date: Jan 2017
PM Sent.
02-26-2017, 05:40 PM | #6 |
Drives: summit white 2011 l99 ss/rs Join Date: Jan 2011
Interested in parts but your pm box wont exept new messages. Please pm me
02-26-2017, 06:08 PM | #7 |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
02-26-2017, 10:04 PM | #8 |
Note: This product is a direct bolt on for 2012+ SS Coupe, ZL1 and 1LE.
Note: 2013 Camaro models vehicles with electronic steering require a different front sway. Note: 2010 and 2011 Camaro SS models will need to upgrade to the new GM designed FE4 lower control arms AND Pfadt Front Endlink kit for proper fitment. (See Product Options above) Note: 2013+ Camaro SS Convertible will need GM Rear Endlink Part Number 1410139 to complete installation. (See Product Options above) Note: This product will NOT fit any year V6 Camaro without upgrading to the V8 Brembo rear brake package. Read more: http://www.phastekperformance.com/20...#ixzz4Zr4aiUfX |
02-26-2017, 10:06 PM | #9 | |
Thanks for the info! Very helpful! Sent from my iPhone using Tapatalk
02-26-2017, 10:08 PM | #10 |
02-26-2017, 10:11 PM | #11 |
Yes
03-01-2017, 04:22 AM | #12 |
Drives: 2015 Camaro LFX A6 Join Date: Nov 2015
Still available?
I can't for the life of me figure out why having rear Brembo's would matter for this kit on a V6 ? Can someone enlighten me. I do have front 1LE Brembo's on order but my rears will remain stock for now at least. Very interested in this kit. Will it fit my V6 or not?
Cold Air Inductions CAI : Apex Air Scoop / WW Relocate Kit : JacFab Intake Manifold Spacer : Overkill 80mm Throttle Body : Overkill Tuned : MagnaFlow Cat-Back Exhaust : Elite Engineering Catch Can : ZL1 Strut Tower Brace : Custom Tunnel Brace : JPSS Caster Locks : JPSS 32mm Rear Sway Bar : JPSS Billet Radius Arm Bushings : Pegasus Solid Sub Frame Bushings : 1LE Brembo Conversion : B&M 70273 Trans Cooler
03-01-2017, 12:28 PM | #13 |
Yes they are still available.
I don't know the answer to your question. I know that 2010-2011 need the rear lower control arms upgraded to the 2012+ design on all models. If it's a V6 in those years the stock rear brake calipers will interfere. I don't know what the situation is on 2012+ V6's. Anyone??? Sent from my iPhone using Tapatalk
