12-03-2020, 03:51 PM | #1 |
Drives: 2019 Camaro 1LT Join Date: Feb 2020
Square Setup 6th Gen
Hey, I'm just wondering if it would be possible to run this square wheel and tire setup on my stock 19 Camaro. I'm looking to run 20x10.5 inch rims with 42 offsets and have 275/35ZR20 tires. Just wanted to know if these are going to fit on my stock suspension and if there might be any fitment issues. Thank you.
12-03-2020, 04:01 PM | #2 |
Monterey County Camaros
I run a 275/35R20 with 9.5" rims. Slight issue with rubbing on the fronts when making hard right/left turns. But after a couple of months of driving the tires wore down just enough to where they wouldn't rub.
I don't see why your setup wouldn't work.
Follow us on Instagram @montereycountycamaros
12-04-2020, 07:23 AM | #3 |
Drives: 2017 Camaro 2.0T, 91 Miata Join Date: Jan 2020
With that offset, you'll need about a 20 mm spacer.
My autox setup is a 19 x 10.5" et22 wheel with 305/30-19 tires, and they just barely fit. So yours should fit if you get the right spacer.
03-01-2021, 08:07 PM | #4 |
Drives: 2020 Chevy Camaro SS Join Date: Jul 2020
03-02-2021, 04:27 AM | #5 |
Drives: 2018 Camaro SS Join Date: Jan 2021
Seems like a skinny tire for a 10.5 rim.... are you going for stretched look?
Sent from my iPhone using Tapatalk |
03-02-2021, 06:52 AM | #6 |
Yeah I agree! The tires will be a bit stretched on 10.5 inch wheels.
Tags |
#tires #wheels #looking #tire |
