Vararam
Old 09-27-2020, 11:22 AM   #1
iLilDark
Drives: Camaro 2013 LT
Need spoiler suggestions
I know it's an old discussion but let's see them spoilers suggestions, I wanna change my ss spoiler I thought of getting the zl1 along with wickerbill but damn those wickerbill extentions are expensive so I thought to myself if I'm in the budget for $300-500 I wouldn't mind installing something different, either way let's see pics of them spoilers 😍
iLilDark is offline   Reply With Quote
Old 09-27-2020, 02:07 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
I went with Kurt's Z/28 replica: https://www.aerosportconcepts.com/st.../Spoilers.html
Don't have any pics of mine but I could get some if so desired. I didn't get the wicker bill but am considering making my own one day.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
KillboyPowerhead is offline   Reply With Quote
Old 09-27-2020, 03:12 PM   #3
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
I'm getting an Anvil notched spoiler for my ZL1. The ZL1 in Red Hot I will put up for sale. I wanted a carbon fiber spoiler to match the hood insert.
FasNuf is online now   Reply With Quote
Old 09-27-2020, 06:32 PM   #4
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
Anvil notch compared to the factory “spoiler”.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
Old 09-27-2020, 06:34 PM   #5
FasNuf
FasNuf's Avatar
Yea! That looks way better.
Old 10-02-2020, 05:17 PM   #6
FasNuf
FasNuf's Avatar
I received my Anvil notched spoiler yesterday. I'm happy with the product, not so happy with my old spoiler totally destroying the paint that was under it. Chipped paint down to the primer mostly near the end of the lid. The new spoiler almost completely covered where the old one was except a very small spot and in front of the middle area which wasnt damaged. I have some single stage in RedHot that Im going to try touching it up to at least get color back on it.
Old 10-02-2020, 05:24 PM   #7
Trawz
Trawz's Avatar
Drives: 2013 Camaro 1LE
Went with this Z/28 replica.
https://extremeonlinestore.com/colle...31457715912771
Bolted right up and comes with a wicker bill and hardware for under $200.
Trawz is offline   Reply With Quote
Old 10-02-2020, 05:57 PM   #8
FasNuf
FasNuf's Avatar
Wish I could say mine was cheap but I really wanted real carbon to match the ZL1 hood carbon. Not a perfect match but it is carbon. I really like the Z/28 one too.
Old 10-02-2020, 06:07 PM   #9
StingrayblueSS
StingrayblueSS's Avatar
Drives: 2013 Camaro SS
I went with the ZTA spoiler. https://www.phastekperformance.com/2...poiler-113.htm
2013 Camaro SS
Kooks Headers Vararam DRX 1le Differential 3.91
Bo White throttle body Magnaflow Competition Exhaust
12.391 112 MPH 10/05/19
StingrayblueSS is offline   Reply With Quote
Old 10-02-2020, 08:18 PM   #10
Camaro2ss2010
I would recommend getting some rubber grommets and putting between the spoiler and trunk lid. It will rub agains the body on the rear. I found this out the hard way. I can show the grommets I used if interested.
Old 10-02-2020, 08:31 PM   #11
FasNuf
FasNuf's Avatar
The damage from the OEM spoiler is covered with the new one but will be exposed if the grommets raise the new spoiler too high.
Old 10-03-2020, 11:48 AM   #12
FasNuf
FasNuf's Avatar
Send some pics !
Old 10-03-2020, 03:35 PM   #13
Camaro2ss2010
Send some pics !
I used these from Lowe’s. Pick what size you think you will need. They obviously compress a little when you tighten the spoiler down. You can see what mine did in a short period of time. Haven’t had a problem since I put the grommets in between.
Old 10-03-2020, 04:00 PM   #14
FasNuf
FasNuf's Avatar
Looks like a good idea! They would also help seal out water from going down the holes.
