Go Back   CAMARO6 > CAMARO6.com General Forums > Regional Sections > USA - Texas
Old 10-03-2022, 05:58 AM   #1
Wolfman1
Drives: 2017 Camaro SS
2017 Camaro SS 2SS A8 problem
A8 manual mode not shifting properly...need reliable transmission shop in San Antonio area or 'stealership' recommendation.
Wolfman1 is offline   Reply With Quote
Old 10-09-2022, 09:58 AM   #2
Irish Luck
Drives: 18' Zle ngm
Would start with changing trans fluid and filter before taking to dealer if you can. On my 2016 every 4 oil changes is when Trans acts up and rear end gets noisy on the lsd so both get fluid changes.
18' Zle ngm
16' 2ss vert sim
18' 4runner
Irish Luck is offline   Reply With Quote
Old 10-18-2022, 10:26 PM   #3
BobKat
Drives: 2017 Camaro
So I took mine in not too long ago ... month or 2 ago .... the 8speed has an issue and torque slipping ... there is a Service Bulletin on it ..... the dealership will know about this ..... it is known in all the vehicles that have had that transmission. The above info came from a Chevy trans tech guy at the dealer .....
We both took the car out for a test drive and he hooked his computer up and was able to show/tell me when it was slipping. It felt like a shimming going on in the front to me. I could feel it in the steering wheel.
The fix was a "Update HP trans fluid" .... costly ... but it did fix my issue
I would call the dealership and ask them for ANY SB on that transmission
BobKat is offline   Reply With Quote
