08-15-2022, 03:51 PM | #71 | |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
Also, a GM Tech told me the ECU will only be ok with 2 modules with non-matching VIN numbers. @Krispy, I doubt control modules are big sellers so not too surprised they are relatively cheap. ZL1 1LE wings otoh, you'd think those are made of gold for what people want for them.
08-15-2022, 04:38 PM | #72 |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
I just bought one from an auto-wrecker in AZ from a 2020 ZL1 with a10 via Ebay.com like you suggested, thanks a bunch!
Apparently it was stored inside and out of the rain, and since there isn't a dryer climate than AZ so I guess it's reasonable to assume it will work fine and better than any other used option... Time to save $2000!
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
09-12-2022, 08:44 AM | #73 | |
Drives: Camaro SS 1LE Join Date: Jun 2021
10-17-2022, 01:29 PM | #74 |
Yes despite what the dealership thought, the car was able to accept the new EBCM ABS module just like I was told on this forum, despite the different VINs, thanks guys!
I have not yet been able to test at the track
10-17-2022, 08:36 PM | #75 |
not afraid of the wall
Drives: Camaros Join Date: Apr 2010
I’m not nearly as experienced as others who have already posted - nor do I have my 6th gen yet - but what you described is exactly my experience with my 13 1LE that drove me nuts even after upgrading. Here’s what it “boiled” down to in resolving:
1) I had the ABS module bled 2) I changed my driving style The 5th Gen is heavier than your 6th; however, I was making 500rwhp. Supercar3 tires, Motul fluid, ST43’s with stock 4-piston Brembos I had the propensity to brake late and hard, and it would be immediate WOT to hard on the brakes. I finally got to where I figured out just how to induce ice mode any time - and also how to always avoid it. Like others have said, though, there is a pedal feel that differs between ice mode and when you’ve cooked your fluid. After the ABS flush I finally stopped having fluid issues. I also stopped ever having ice mode simply by changing from that immediate WOT-to-brake stab in to a more linear first hit on the brake pedal and down. I didn’t watch your videos but am confident based on your comments that you’ll have much better experience next time out - with your new cognizance to your braking habit (and the ABS flush)
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100 Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z |
10-18-2022, 02:56 PM | #76 | |
