08-13-2022, 07:48 PM | #57 | |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
The big advantage of the ZLE that you can't upgrade a non-1LE to is how all of the electronics are programmed. ABS, traction and stability controls are all programmed around the ZLE suspension and the 305/325/30/19 GY3R tires. I am also not sure what you experienced is technically ice mode, there is more than one cause for the ABS system to limit braking force and I think one of those situations has mostly to do with the combination of requested braking force combined with speed and steering angle. Ice mode cause is more of a differential in wheel speeds side to side or front to rear, so if one side of the car is on a different surface than the other it'll limit braking to prevent a spin, or on high grip to low grip transitions it may limit braking to preserve stability. This is why a square setup can make the issue worse, the car wants to see a higher wheel speed up front because the OEM setup is staggered, so a square setup puts the ABS logic closer to the threshold of a high to low grip transition. I do not know for certain if the ZLE ABS system won't limit braking in every single scenario, I have heard it has no ice mode but not verified with a GM engineer... but it will certainly be programmed for the additional grip the suspension and 3R tires provide. It is certain the '19+ ABS is upgraded as described by the GM engineer in the AutoX thread. How much of a difference that will make for you is also uncertain.
08-14-2022, 11:59 AM | #58 | |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
08-14-2022, 12:06 PM | #59 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
From what I recall speaking to someone on the GM autox team a while back, the changes to the ZL1 and SS 1LE were not all that extensive. The biggest changes were supposed to be with the SS cars. The ZL1 1LE, you are right, I don't think was touched.
An issue with trying to swap modules: 1. Everything these days, if you order a brand new module, comes as a "dumb" module and requires programming upon installation. This is done per your VIN. 2. When trying to swap modules from various model years (i.e. a 2019 module off a wrecked car into a 2017 car): sometimes there are various changes to the electrical system between model years and this doesn't work. It could be due to internal hardware changes to modules (might not be the module in question and could be a module in the line of communication) and it could be slight changes in programming due to a variety of reasons, where installed in a different model year may cause some communication issues. Think about this: 2016 modules are simpler and easier to unlock, where just the next model year, 2017, are a little more difficult, yet the majority of Camaro is the same 2016 to 2017. |
08-14-2022, 01:04 PM | #60 | |||
Drives: Chevrolet Camaro, Ford Mustang Join Date: Oct 2019
Will look forward to your update following your next event, and trying 'Right foot braking'. Best regards, Dave
2022 SS 1LE - Vivid Orange - SCCA CAM-C & Optima Ultimate Street Car GT
Katech, MSD, QA1, Hurst, Anderson Composites, ProParts USA Custom Suspension, MFR Engineering, Forgeline Wheels, G-Loc Brakes, Nine Lives Racing, MTX Audio, Penske Rapid Repair |
08-14-2022, 08:36 PM | #61 |
Hmmm well I hope I did not waste my money with the new EBCM, since I’ll have change my driving style anyways… If both these things together solve the issue, I guess I may never know for sure how much a new EBCM did…
08-14-2022, 08:59 PM | #62 | |
But yes, just change the left foot braking behavior, and you should be good! Best regards, Dave
08-14-2022, 10:13 PM | #63 |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
I am right foot braking in my SS 1LE but I still sometimes get ice mode on stock tires and stock brakes in certain spots on different tracks. I posted more details recently in the Ice Mode thread. Idk if the result would be different if I used the same technique in a ZL1 though.
08-15-2022, 12:12 AM | #64 | |
I bought a new EBCM from GM through my dealership that will be arriving this week for installation, But now I realize it apparently comes blank and I will need my dealership to flash program it using VIN number from a 2019 or newer ZL1 with the same options as mine, mainly the A-10 automatic transmission. I did not realized the later part, so I’ll find out from my dealership what they can do early this week…
08-15-2022, 12:11 PM | #65 |
Drives: Camaro SS 1LE Join Date: Jun 2021
GunMetalGrey, I'm very interested in the outcome of the EBCM swap & program, when is your next scheduled track day after installation?
I have a '17 SS1LE with 18" 315 square tire setup(Nankang CRS) and am having intermittent brake performance manifesting itself very simiilar to yours. Unfortunately many of the local tracks I attend have bumpy brake zones which makes the problem extremly pronouced. Yes, I can drive around the problem with being more conservative with the brakes however it's costing performance/laptime. It wasn't a problem for me last summer with the OEM staggered SC3 setup. Any other potiential EBCM "solutions" other than swaping 2019+ unit, or buying a ZLE? What are people with heavily modified race cars doing? Any aftermarket products? |
08-15-2022, 12:26 PM | #66 | |
08-15-2022, 02:39 PM | #67 | |
08-15-2022, 03:08 PM | #68 |
Does it not seem strange you can apparently get these on eBay for ~$60 but from a dealer it would be ~$1.5k?
08-15-2022, 03:13 PM | #69 | ||||
I ended up purchasing everything off eBay, from a salvage car, where they were selling on the BCM's... just make sure the options/package/model of the vehicle with removed BCM's are what you're looking for. This is how I updated my Rear Diff Controller and Shocks, by installing ZL1 1LE modules. Quote:
Best regards, Dave
08-15-2022, 03:40 PM | #70 | |
One question, how do you know that you are for sure getting the right match (in terms of same trim and the right year) when it's off ebay? I guess there is no reason to lie unless there is a big enough market for this EBCM thing, which I doubt
