TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro Price | Ordering | Tracking | Dealers Discussions > Guides, Manuals, Bulletins, Documentation Archive
Old 05-22-2016, 10:49 AM   #1
Cami-Girl
Drives: 2013 Camaro 2LS
Need correct OEM part numbers
RE: 2013 2LS...Can anyone tell me the correct OEM part numbers for:
(1) Rear bumper facia face/cover (less the holes located on either side of the back-up lights and less the obstacle detection sensor).
(2) Rear bumper exhaust facia molding, black.
Also, when they talk about the "rivet strip", are there actual rivets I would have to deal with to remove and replace the facia and the molding or do I get lucky and only have to remove bolts and screws?
Cami-Girl is offline   Reply With Quote
Old 05-23-2016, 12:22 PM   #2
Mr. Stacy
El Duderino
Mr. Stacy's Avatar
Drives: 2011 2LTRS Convertible
There are two versions based on how the vehicle is equipped:
Most of the part numbers can be found here:
https://www.gmpartsonline.net/parts/...iagram=CD10665
It looks like there are a few rivets that will need to be removed, replaced. #9 and #11 on the diagram. However you may not have to get to these.
Somebody who has done it might be able to chime in here...
I bowl. Drive around. The occasional acid flashback.
Mr. Stacy is offline   Reply With Quote
Old 05-23-2016, 08:13 PM   #3
Cami-Girl
Yeah, I found this one too, but from what I could figure out on this site, they only had the diagram for the 1LS. This one shows the holes on either side of the back-up lights....my car does not have these.
Since this facia is plastic, do you know if they've come up with some sort of "Bondo" that can be applied on plastic yet? Maybe some sort of an apoxy?
If there is, then I'd only have to replace the bumper molding.
