Old 09-01-2023, 04:49 AM   #1
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
Upgrade from SS to 1LE Brake Calipers
What all is necessary to upgrade my Brake Calipers from the stock SS calipers to the 1LE calipers for the fronts and rears?
Need4Camaro is offline   Reply With Quote
Old 09-01-2023, 08:06 AM   #2
rcoe
rcoe's Avatar
Drives: 2016 Camaro SS
For the front you will need the calipers, pads, rotors and longer lines.
Rears are the same I believe.
I ordered the front kit from GM performance parts, very quick and easy install.
2016 Camaro 2SS 759whp 686wtq tuned by KingLt1
Procharger D1SC - Diamond Pistons/Manley Rods
BTR stage 3 cam - Circle D converter
American Racing headers - Borla S-type
rcoe is offline   Reply With Quote
Old 09-01-2023, 10:40 AM   #3
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
or you can just buy a zzp bbk like i did for my ss
kropscamaro16 is online now   Reply With Quote
Old 09-01-2023, 11:38 AM   #4
Need4Camaro
Is this it?
https://zzperformance.com/products/c...30873177325630
Old 09-01-2023, 02:05 PM   #5
rcoe
rcoe's Avatar
Originally Posted by Need4Camaro View Post
Yes.
Nice kit I just wanted red calipers.
Old 09-01-2023, 02:13 PM   #6
kropscamaro16
yessir they only come in yellow or silver but you can always redo them or paint them
Old 09-01-2023, 02:55 PM   #7
Need4Camaro
I want mine to be blue because my car is Silver Ice Metallic Blue, who can I get to powdercoat them that color?
Old 09-01-2023, 03:51 PM   #8
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
You DO NOT want to powdercoat the calipers if using them for heavy track use. You want to have them CERAKOTED. Thise would be good up to 800-900 degrees which you should NEVER see.
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 09-01-2023, 07:21 PM   #9
Need4Camaro
Where should I get that done?
Old 09-02-2023, 12:35 PM   #10
Need4Camaro
I have another question now.
What Brake Pads should I run considering I want to DD as well as track or road course the car?
Old 09-02-2023, 02:55 PM   #11
Baddawg53
Drives: 17 hyper blue 2SS M6
This is good advice! I definitely made that mistake and in short order my calipers were a mess, I had underestimated how much heat they'd see on track.
Baddawg53 is offline   Reply With Quote
Old 09-02-2023, 02:59 PM   #12
Baddawg53
Maybe start with the OEM 1le pads, they're plenty good enough for the street and doing track days. And they won't be noisy like track pads can be
Old 09-03-2023, 08:15 PM   #13
The Chief (tm)
The Chief (tm)'s Avatar
Drives: 2016 Camaro 2SS "Convertibobble"
Possible / probable dumb question: would the ZZP kit (or similar) require any sort of re-tuning of the ABS brains?
'16 2SS Garnet Red ~24K
"Mods": GM wind deflector, home-made rear seat delete & platform, not-quite garnet red key fob cover (+10rwhp)
'99 4Runner 367K
'94 ST1100 146K
The Chief (tm) is offline   Reply With Quote
