10-02-2020, 08:27 AM | #337 |
Drives: 2017 Camaro SS Join Date: Jun 2020
Early results are good. No vibration. We'll see what happens after a few hundred miles.
10-02-2020, 09:11 AM | #338 |
Drives: 2018 2SS M6 Hot Wheels Camaro Join Date: Mar 2017
I hope you have good luck like I have so far. I have a 2017 1SS with the A8. After about a year and 2500 miles, I noticed the shudder. Got the first flush, and it was good for about a year and another 1500 miles. The shudder came back, and when I called, the dealer informed me of the new flush that is supposed to be a permanent fix. I had that done about 3-4 months ago, and after about 500 miles, so far so good. It’s my weekend cruiser, so I don’t have a big mileage sample to go on.
2018 2SS M6 Hot Wheels Camaro loaded (Moonroof, Magnetic Ride Control, NPP, etc…)
Previous cars: 2017 1SS Nightfall Gray Metallic w/A8 and NPP 1988 IROC-Z (tons of mods), 1995 Z28, 1998 Z28, 2006 GTO, 2010 Camaro 1SS, 2015 Subaru STI, a couple Acuras and multiple Jeeps. |
11-07-2020, 12:08 AM | #339 |
Drives: 18 Camaro SS Join Date: Jun 2019
Not even 2 years ago I went through this saga of triple fluid flushes doing nothing and they finally swapped the torque convertor. Now with the replacement one the shudder is back. Curious to see how they handle this problem now.
11-07-2020, 05:58 AM | #340 |
Drives: 2021 Camaro LT1 Join Date: Sep 2020
GM never found a true fix and i really don't think anyone knows what is going on. People that say it is fixed will run into the shudder again out of warranty and good luck then. So no A8 cars for me ever.
11-07-2020, 06:01 AM | #341 |
That is when my new 2019 C7 would shudder around 60mph. It was built in Feb 2019 with the new so called fluid and started to shudder at under 250 miles. And i even had a Ranage device. You could feel it coming and going at a steady 60.
11-07-2020, 07:52 AM | #342 | |
Drives: 2018 Camaro V6/RS Join Date: Nov 2018
You had the latest fluid and flush procedure done? |
11-07-2020, 11:18 AM | #343 | |
11-07-2020, 09:42 PM | #344 |
Tuned my A8 immediately upon purchase of my car back when it was new. Have never had any shudder FWIW.
11-23-2020, 02:20 PM | #345 |
Drives: 2016 2SS blue velvet w/blk stripes Join Date: Sep 2017
2nd time getting flushed
Well i got about 1000 miles on my 2nd flush job with the supposedly new fix all end all fluid. Seems to feel like its doing it again. But now seems like its doing it at a wider range of speeds and gears. Normally when i feel it shudder i can put it in 7th and it goes away. Now it seems like its always doing it. that rumble strip feeling. is there any other driveline issues i dont know about that would be reminiscent of TCC shudder? Thanks group.
11-23-2020, 03:17 PM | #346 | |
Not sure where you are with your powertrain warranty, but it should cover this job. Make sure you find a helpful dealership. If you're past the end point, the new revised torque converter itself isn't very expensive, but replacement involves significant labor. You might as well get the transmission tuned, it will almost feel like getting a new car with a better trans.
12-29-2020, 03:00 AM | #347 |
Drives: 2016 2SS Join Date: Oct 2018
Hey everyone, sorry that I have not kept up with this thread. My last post was back in January after my torque converter was replaced. Please see my last post for more details.
After you have received your first flush with HP fluid, my 2016 took ~3000 miles before the shudder came back permanently. Please try to get those miles on it as quickly as you can, if the clutch is damaged the problem will return. I felt very short instances of shudder at 2500 then at ~3000 it was permanent. You’ll know it when it starts acting up again and you want to be able to show the problem has persisted. Once the shudder returns work with your dealer to get the torque converter replaced. I have ~2900 miles on my new TC and not even a hint of the shudder returning, it’s been really good and so far I am pleased with the results. It’s been so nice to drive around and not worry about it. There is light at the end of this nightmare but, as mentioned, you have to find a reputable dealer and have patience. Nothing pissed me off more than this A8 shudder but patiently working with my dealer to get through the problem was a win for everyone.
2016 Camaro SS
Stance SF06; Borla S-type NPP; Brembo; Oracle Concepts; 6LE Designs |
01-08-2021, 09:10 PM | #348 |
3 Camaro man!
Drives: Camaro 2.0 T Join Date: Jun 2014
Camaro Converter Shudder
If GM fixed the problem on 2017 A8 models how come I have the exact same problem on 2018 2.0T 10 speed 6th Gen Camaro ?
01-08-2021, 09:14 PM | #349 |
3 Camaro man!
6th Gen Camaro Converter shudder
If GM fixed the problem on 2017 A8 models how come I have the exact same problem on my 2018 2.0T 10 speed 6th Gen Camaro at only 2,000 miles ? Someone is a liar !
01-08-2021, 09:17 PM | #350 |
3 Camaro man!
