Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 02-24-2020, 10:25 PM   #29
IWANTA(ss)
IWANTA(ss)'s Avatar
Drives: 13 1LE 1SS/05 ZX10/02 Silverado/14
Originally Posted by Joe M 2012 2SS View Post
I'm sure GPI didn't do anything wrong. The problem is Motive, they used to make high quality gears in Italy, they have been bought out a few years back, and now are made in China.
I had Motive 3.91's put in with my tru-trac by someone with 40 years experience, pattern was perfect, backlash spot on, whined like crazy. Poor machining. Switched to AAM, and after many passes at the drag strip it has developed just a little whine, but no where near what the Motive's did.
I didn't think that either but didn't know that about motive. I'm going to call GPI and see what they think in the morning
02 Stepside Silverado
05 ZX-10
13 1LE
14 Nightrod Special
IWANTA(ss) is offline   Reply With Quote
Old 02-24-2020, 10:32 PM   #30
IWANTA(ss)
IWANTA(ss)'s Avatar
Originally Posted by oldman14ss View Post
WOW! that is noisy! I'm no expert but my opinion is that is way to loud. my ring and pinion is set up a little closer to the toe for competition as shown in the truetrac manual at 5k back lash. its still on my blocks waiting for me to finish. I guarantee if mine are singing they are going back to my installer. now there are 5 cut gears and two cut gears. 5 cut so ive read are harder to set up because of the taper in the gears.
I wish I could just drive the car to them and leave it and let them do the heads while they have it lol. but my plan is to do the 500 miles and change the fluild and see if it goes away when I go over 60 and cruise if not Im going bite the bullet and send the diff back
05 ZX-10
13 1LE
14 Nightrod Special
Old 03-06-2020, 03:52 PM   #31
IWANTA(ss)
IWANTA(ss)'s Avatar
Talked to GPI they said to finish the break in and judge it then. They also said the offset bushings carry a lot of noise along with the lpw cover. And I’m so guessing the Pegasus bushings is accounting for some noise to. But I’m only 150 miles away from the 5 so we will see.
05 ZX-10
13 1LE
14 Nightrod Special
Old 03-31-2020, 06:29 PM   #32
IWANTA(ss)
IWANTA(ss)'s Avatar
Hit the 500 mile mark last week drove the car out of town and it whined Lol but with the solid bushing and etc in the rear I think that is how it’s supposed to sound.
Overall though they work and really well
21.9 mpg turning 1800 rpm at 73 mph in 6th gear with fbo and SS4 cam
The acceleration is very noticeable even coming from the 3.91 the car feels lighter.
But I have no idea what the true trac is supposed to feel like when it’s working can someone give me a little help.
05 ZX-10
13 1LE
14 Nightrod Special
Old 04-01-2020, 08:21 PM   #33
oldman14ss
Drives: 2014 1ss camaro
yeah I hit 500 and have whine on the coast side of the gears. I have another problem though. my right axle nut came loose and left the planet! don't know how long it was gone. I see no diff leaks. gonna crank it down real tight this time and listen to the bearings.
oldman14ss is offline   Reply With Quote
Old 04-01-2020, 08:47 PM   #34
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
For lack of a better description at the moment. The diff will feel like it is locked. It is going to feel a little different compared to an lsd.
The axle nut is torqued to 199ftlbs.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come.
Black_SS10 is offline   Reply With Quote
Old 04-02-2020, 06:25 AM   #35
IWANTA(ss)
IWANTA(ss)'s Avatar
Torque it to spec then stake the nut.
Originally Posted by Black_SS10 View Post
For lack of a better description at the moment. The diff will feel like it is locked. It is going to feel a little different compared to lsd.
I’m coming from a 02 single cab Chevy what does a locked diff feel like?
05 ZX-10
13 1LE
14 Nightrod Special
Old 04-02-2020, 08:29 AM   #36
Black_SS10
SomeguyK
Black_SS10's Avatar
Ths Trutrac is a helical diff and operates similar to a clutch based LSD. It can operate as an open diff and apply power equally to both tires. Since it is gear and not clutch based it can feel more mechanical and have a locked feeling when bias is generated.
More to come.
Old 04-03-2020, 08:30 AM   #37
IWANTA(ss)
IWANTA(ss)'s Avatar
Would you say it feels like the rear squats down under hard acceleration
05 ZX-10
13 1LE
14 Nightrod Special
Old 04-03-2020, 08:34 AM   #38
Black_SS10
SomeguyK
Black_SS10's Avatar
That feeling can happen. You applying equal power to both wheels. No slipping of clutch packs in the diff anymore. It will feel very direct.
More to come.
Old 04-05-2020, 08:09 PM   #39
oldman14ss
I have 3:70 aam, trutrak, red poly diff bushing, toe rods and arms with poly. why so whiney? dot get it.
Old 04-06-2020, 02:06 PM   #40
IWANTA(ss)
IWANTA(ss)'s Avatar
I don’t kno 4.11 are a little bigger and I also have the aluminum sub frame bushing and derlin diff bushings with the lpw cover
05 ZX-10
13 1LE
14 Nightrod Special
