02-02-2020, 12:32 AM | #15 | ||
Drives: 13 1LE 1SS/05 ZX10/02 Silverado/14 Join Date: Nov 2014
I kno nobody’s perfect but I don’t feel like GPI messed up I never had a gear swap done on a 6speed car so it maybe just normal
02 Stepside Silverado
05 ZX-10 13 1LE 14 Nightrod Special |
02-02-2020, 03:57 AM | #16 |
Angewendet Ingenieur
Drives: 14 Camaro ZL1 Join Date: Apr 2015
Eaton suggests specific mineral based GL5 rated 80W 90 without friction modifiers or synthetic type oils...
https://www.eaton.com/us/en-us/produ...trac-faqs.html |
02-02-2020, 06:34 AM | #17 |
Drives: 2010 camaro limited edition turbo Join Date: Mar 2014
If the noise is as pronounced as you indicate, one can be sure that the contact pattern is incorrect and/or the backlash needs to be adjusted. Setting up proper gear contact patterns on both the drive and coast side is very time consuming and in most all cases, requires several teardowns and incremental adjustments in order to get the patterns correct.
This noise will NOT go away no matter what lube you use or what bushing you have. If it is annoying, the only way to fix the problem is to tear the diff down again and make shim changes. Be sure all bearing pre-loads are mandated first, then on to pinion depth adjustment and backlash until the patterns on both drive and coast sides are all but perfect. Then and only then will the diff be quiet. Hope this helps. Good luck. |
02-02-2020, 07:19 PM | #18 | ||
02-02-2020, 07:44 PM | #19 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
I hate gear noise. I just had mine rebuilt, new bearings, new trutrac (nothing was wrong with the old one), and a new GM OEM 3.91 gear set. I have the LPW cover, billet caps, and offset bushings; along with solid cradle bushings. It has very little noise. I didn't and don't expect it to be silent.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come. |
02-02-2020, 09:44 PM | #20 | |
02-03-2020, 05:15 AM | #21 |
SomeguyK
If it is minor whine, I wouldn't worry too much. Especially with a LPW cover and poly bushings. I'm in for a video, I want to hear how much whine you have. Lol
More to come. |
02-04-2020, 06:02 AM | #22 |
Most gear whine occurs between 45-55 MPH, either during slight loading or deceleration. If the whine is outside these limits and sustained, the differential should absolutely be removed and adjusted. Sustained noise/whine is unacceptable and indicates that the tooth patterns are WAY OFF!!! Don't accept this! However, if the whine is only at certain speeds, very minimal and above and below these speeds, noise goes away, then the contact pattern is close, not perfect but close and no damage should occur over high mileage.
If the later is true, one can live with it if they choose. My high ratio gears, (5.36) which you would expect to be very noisy, are all but quiet as stock. The time & effort in achieving correct gear contact patterns will assure you of almost a perfect setup that will have little to no noise, no matter what ratio gears you are installing. THE CONTACT PATTERNS TELL THE STORY. |
02-09-2020, 07:46 AM | #23 |
How can I upload a video without putting it on you tube first
02-23-2020, 02:13 AM | #24 |
02-23-2020, 08:31 AM | #25 | |
SomeguyK
More to come. |
02-24-2020, 11:41 AM | #26 | |
02-24-2020, 07:54 PM | #27 |
Drives: 2014 1ss camaro Join Date: Jul 2017
WOW! that is noisy! I'm no expert but my opinion is that is way to loud. my ring and pinion is set up a little closer to the toe for competition as shown in the truetrac manual at 5k back lash. its still on my blocks waiting for me to finish. I guarantee if mine are singing they are going back to my installer. now there are 5 cut gears and two cut gears. 5 cut so ive read are harder to set up because of the taper in the gears.
02-24-2020, 08:45 PM | #28 | |
I'm sure GPI didn't do anything wrong. The problem is Motive, they used to make high quality gears in Italy, they have been bought out a few years back, and now are made in China.
I had Motive 3.91's put in with my tru-trac by someone with 40 years experience, pattern was perfect, backlash spot on, whined like crazy. Poor machining. Switched to AAM, and after many passes at the drag strip it has developed just a little whine, but no where near what the Motive's did.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles. |
