10-22-2019, 08:16 AM | #1 |
Drives: 13 1LE 1SS/05 ZX10/02 Silverado/14 Join Date: Nov 2014
Rear upgrade nosies
For those who’ve upgrade the big three in the rear (solid sub frame bushings etc.) what kind of noises do you hear from the change when driving?
02 Stepside Silverado
05 ZX-10 13 1LE 14 Nightrod Special |
10-23-2019, 06:53 AM | #2 |
Nothing it will accelerate better, corner better, less wheel hop, and feel more in control. No noises.
Orange Krush II
10-24-2019, 07:41 PM | #3 |
I got them in already and man do they work as advertised but now when ever the ass end raises up or goes down I hear a loud pop. I got my x-pipe put in today and i looked while it was in the air and I think all the grease has been pushed out.
10-25-2019, 11:14 PM | #4 |
Drives: 2015 Camaro 2SS Green Flash Edition Join Date: Dec 2015
If the rear suspension is popping I’d check torque for all of the suspension components. I’d also recommend clocking the bushings while torquing.
Kooks stepped headers & Solo XL Cat-back
ADM CAI w/race scoop & Rotofab w/w relo GPI VVT SS1 cam and CNC ported heads milled .30 BTR .660 springs, Straub solid bushing trunions GPI rod-mod intake with I-M heat sheild Circle D 258mm Pro single disc 3700 rpm stall converter 169F thermostat & manual fan switch Tuned by Ryno at GPI - 455 RWHP / 416 lb-ft |
10-28-2019, 05:42 PM | #5 |
I have to swap out the diff soon I’ll make sure to torque to everything too spec.
11-14-2019, 06:07 AM | #6 | |
Liv'n The Dream!
Thanks,
Never be afraid to try something new. The Ark was built by amateurs and the Titanic was built by pros.
11-14-2019, 09:00 AM | #7 |
What did you mean by pushing all the grease out??
Orange Krush II
11-24-2019, 06:49 PM | #8 |
All the grease has been squeezed out around the bushings on the trailing arms and toe rods.
