Old 12-13-2017, 11:52 AM   #71
Soleil
Soleil's Avatar
That’s really interesting.
subribe
Soleil
Old 12-21-2017, 11:14 PM   #72
dissonance
dissonance's Avatar
Drives: '18 SS 1LE
Looks good but a square setup and the option to rotate front to back.. TSW 27mm series19x10.5 have about 3 or 4 rims to chose from use 3mm spacer in front or just grind a tad where the shock mounts.. 305 30 19s RE71R 's last pick is MRR reps on Bridgestone RE11S 305 325.
Can't seem to find this fitment/specs for the Bathurst wheel? Did you have them custom built?
Thanks
dissonance is offline   Reply With Quote
Old 12-22-2017, 04:07 AM   #73
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
They fit the zl1 1le no spacers or regular zl1 3mm upfront.
Old 07-24-2018, 12:42 PM   #74
breadwoman
Drives: FRS
Sorry to revive this thread, but I'm looking at a set of BC Forged RZ22s with this size/offset as well. I will need to run max stock front camber at -2.6. How much camber did you have with the wheels on? Did you encounter any rubbing issues front and back?
Thanks.
breadwoman is offline   Reply With Quote
Old 07-24-2018, 05:42 PM   #75
PK Auto Design
PK Auto Design's Avatar
Drives: 2017 Chevrolet SS 1LE
Thanks.
Confirmed for you no issues and he ran them at -2.6 degrees upfront.
PK Auto Design is offline   Reply With Quote
Old 07-30-2018, 08:38 PM   #76
BigShow1960
BigShow
BigShow1960's Avatar
Drives: 2017 1 Camaro + Chevy Avalanche
I'm on the verge of pulling the trigger on a set. I didn't see an answer to the torque question.
BigShow1960 is offline   Reply With Quote
Old 07-30-2018, 08:55 PM   #77
PK Auto Design
Torque for lug nuts I do 110 sir
Old 07-31-2018, 11:00 PM   #78
BigShow1960
BigShow
To make it clear to others, and per your email, the wheels are rated for 140 ft-lbs, which I plan to use. Thanks!
Old 08-14-2018, 09:49 PM   #79
BigShow1960
BigShow
You've got mail...
Almost all of my picture posts on this forum are sideways, what the heck!
Old 08-15-2018, 09:02 AM   #80
S2K+1LE
Drives: 17 SS 1LE | 07 S2K
Since when did mounting the same size tire on two completely different sized wheels become a "square setup"???
It's anything but.
S2K+1LE is offline   Reply With Quote
Old 08-15-2018, 11:43 AM   #81
RacerX78
Drives: 2018 Camaro SS 1LE
You've got mail...
Have you mounted them yet? If so any clearance issues?
It's anything but.
You said it right there. You effectively have the same contact patch F/R.
RacerX78 is offline   Reply With Quote
Old 08-16-2018, 10:37 PM   #82
BigShow1960
BigShow
No time yet to mount. Soon.
Old 08-19-2018, 11:34 AM   #83
BigShow1960
BigShow
First short run with the new set up at Gates Pass, a small canyon practically in my backyard. Stock camber, MRR FS01 19X10.5 5X120 14 MM 67.1 MM Matte Black, MRR FS01 19X11 5X120 36 MM 67.1 MM Matte Black, Bridgestone POTENZA RE-71R 305/30/19 all around. No rubbing or fitment issues observed.
The tires are a bit shorter than the stock Goodyears, shown the old 285s are noticeably more narrow.
To the eye it's a little difficult to tell the wheel apart, I had to measure the rim width to make sure I had the fronts sorted from the rears before mounting.
Old 08-20-2018, 09:29 AM   #84
breadwoman
Drives: FRS
They look awesome, but you should seriously consider track alignment. That front poke is real!
