dave@hennessey
Old 01-06-2021, 04:15 AM   #29
Ashen L99
Ashen L99's Avatar
Drives: Ashen grey, 1SS, L99
Originally Posted by Winemedineme69me View Post
Watch this YouTube video of different sides headers being compared on a 427 engine where the 1 7/8 and 2" made more power than the 1 3/4" but at the end they compare the 1 3/4" vs. 1 7/8" on a canned cammed LS3 and there was no difference other than the 1 3/4" made more torque down low. So, it's not worth me having to buy another set of headers and pay another $400 to replace them again for virtually no gains and maybe even lose torque down low.
Here is the link.
https://youtu.be/O1bXPNy1Yn4
I can tell by the brand of header you have that your not a fan, just like me, of not paying $1200 for bent metal tubing... I’ll never buy kooks, ARH, or stainless works on principle that they way over charge. My argument isn’t based on cubes rather RPM. I promise with any cam choice you make, the car will benefit from having an 1 7/8 primary over the 1 3/4. That tick cam will make power to 7 grand. I bet at 6,500 she starts to choke.
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
Ashen L99 is offline   Reply With Quote
Old 01-06-2021, 07:47 AM   #30
saluki
Drives: 2017 Silverado
Stock cam scales all the way to 2". It starts tapering off hard at 1 7/8 on stock cam but 5hp is still extra 5 hp over the 1 7/8. Any aftermarket cam is going to be screwed on 1 3/4.
'14 2SS A6, CAI, 2" TSP Headers and tune: SOLD
'13 SS @ Burkhart Chassis
saluki is offline   Reply With Quote
Old 01-06-2021, 02:56 PM   #31
_Onyx_Wolf_
Onyx_Z7 <— Instagram
_Onyx_Wolf_'s Avatar
Drives: 2013 2ss 1le
I'm actually going to get the tick polluter stage 3 cam, as far as the headers all the dyno test videos I've seen on the LS3 that the 1 7/8 really doesn't give much of anything and you actually lose a little torque down low. Unless I'm going big cubes or forced induction I'm not giving up much of anything with the 1 3/4 and more torque down low. I want to change it the harmonic balancer anyway because they are crap and wobble , so might as well do the UD pulley.
I had a tick stage 3 polluter cam and it was badass tons of low end tq
_Onyx_Wolf_ is offline   Reply With Quote
Old 01-11-2021, 12:03 PM   #32
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
With a solid bolt on list no reason you cant clear 480. Personally the split doesnt need to be that much but to each grinders own theory lol I cleared 500 with a 226/236 cam and 530 with a SS4
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 01-11-2021, 12:16 PM   #33
Winemedineme69me
Winemedineme69me's Avatar
Drives: Camaro ss Chevy
Originally Posted by Warship2k15 View Post
So you are trying to say that a test open headers with different header extensions is more valid then a wheel dyne test with the engine in the car with the full exhaust.
I think someone just doesn’t want to change headers so they are trying to validate there decision.
It’s all good it’s your car do what you want.
But I can’t agree.
What I'm saying is that I'm not seeing how spending another $400 installation labor and another $300 for 1 7/8" headers is going to be a wise choice, to gain 5 hp at 6500 rpm?? It just doesn't make any financial sense to switch them. I got the 1 3/4 for headers for $200 shipped brand new.
Winemedineme69me is offline   Reply With Quote
Old 01-11-2021, 01:12 PM   #34
Winemedineme69me
Very nice, I hear nothing but great things. I have 3.91 gears too
Old 01-11-2021, 02:28 PM   #35
saluki
With a cam it won't be just 5 hp it will scale up into the double digits pretty easily.
Old 01-12-2021, 10:39 AM   #36
Ashen L99
Ashen L99's Avatar
Agreed.
Old 08-04-2021, 02:16 PM   #37
Winemedineme69me
I have the ESS tuning G2 running the 200mm lower and 110mm upper pulley at 12psi on my 2014 Camaro SS LS3. I just put down 780rwhp at 7200rpm on a Dyno jet, I am running 93 pump gas with boostane at 100 octane. It was tuned by Jared at compJLT tuning in Victoria Texas.
Mods are:
Elite Engineering E2X ultra catch can
100 octane pump gas with boostane additive
160 degree tstat
Stock heads, stock intake manifold, stock throttle body
BTR rocker arm trunnion upgrade
Dual valve springs
Texas speed stage 3 blower cam
Melling high pressure oil pump
Ls9 3 bar map sensor
ESS tuning G2 blower kit with 200mm lower pulley and 110mm upper pulley
Ballenger AFR 500v2 wideband
FIC 80lb injectors
ZL1 fuel pump
DSX auxillary fuel pump kit
DNA motoring longtubes, no cats and stock NPP exhaust
AAM 3.91 rear end gear
BMR rear toe rods and trailing arms
