12-09-2020, 07:12 PM | #1 |
Drives: Camaro ss Chevy Join Date: Nov 2020
Opinions on the TSP cleetus mcfarland bald eagle NA LS3 cam
Hi guys,
What's your take on the TSP bald eagle NA cam? Anything else you recommend? I want a cam that's not going to beat up my valve train, I won't be drag racing but instead just cruising the highways. I've got a 2014 Camaro 1SS LS3 with 98k miles with the following mods. I seafoamed the engine with 4 spray cans through the brake booster line going into the intake manifold to clean out the top of the engine. Dyno Steve tune with SCT x4 KN CAI with metal inlet tube I wrapped in aluminum heat wrap tape. NGK TR6 iridium plugs Taylor 8.6mm plug wires DNA motoring 1 3/4" long tube headers No cats with factory NPP exhaust with fuse pull AAM 3.91 gears |
12-09-2020, 07:21 PM | #2 |
Drives: 13' 1LE Join Date: Apr 2012
I think 229/242 600' 600' wont be too bad for your valvetrain. You could get away with single springs too.
Its a bit large for your needs, but nothing bad. I would run it. With a good tuner, you'll be alright with this cam if you ain't a *****
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
12-09-2020, 07:39 PM | #3 |
What kind of power you think I'll get?
12-09-2020, 07:57 PM | #4 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
450/425 to the wheels is my guess...
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
12-09-2020, 08:06 PM | #5 |
12-09-2020, 11:25 PM | #6 |
Depends mostly on the dyno and what other supporting mods you have and what fuel.
Anywhere from 445-480...
13' 1LE
12-10-2020, 05:07 AM | #7 |
Drives: 2015 Camaro SS Join Date: Sep 2011
You have electric steering, maybe 5 rwhp.
2015 Camaro 2SS Cam/Heads/FBO 498/447 SAE |
12-10-2020, 06:41 AM | #8 |
12-10-2020, 06:42 AM | #9 |
12-10-2020, 12:28 PM | #10 |
Not when you have electric steering ( cost vs HP gained) I would rather spend that money elsewhere on the build.
12-10-2020, 12:34 PM | #11 | |
Do you recommend maybe thinner head gaskets to increase compression? Go from the stock .50 head gasket to say a .40? |
12-10-2020, 01:05 PM | #12 |
Trunnion kit. Personally, I wouldn't do a cam swap without it.
12-10-2020, 01:08 PM | #13 |
12-10-2020, 02:03 PM | #14 | |
