10-02-2019, 01:37 PM | #1 |
Drives: 19 zl1 Join Date: Dec 2015
Line lock and getting the most out of it
So I'm just finishing my first set of of f3s off.
I'd like to be able to leave a nice strip coming off the line coming out of line lock but it seems the car shuts itself down not long after releasing line lock. Is this just the way it is or is there a way to override the shut down out off the break burn? |
10-02-2019, 02:09 PM | #2 |
Drives: 2018 ZL-1 Join Date: Jan 2018
Line lock is for burnouts, not launching.
10-02-2019, 02:17 PM | #3 |
10-02-2019, 02:19 PM | #4 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
I believe the line lock holds itself for 15 seconds but you can end it early by pressing the middle buttons on either side of the steering wheel at the same time. The on/off for the cruise and the ok button.
I think you can end it early but am uncertain. And for it shutting itself down, I'm not certain on that either. There hasn't been a reason for me to use it yet...... Look in the manual and it will tell you how to operate it. |
10-02-2019, 02:21 PM | #5 |
Thanks vigilante. I do believe it shuts down ofter leaving the line...
Too bad....because it's always nice to leave a crazy black mark down the road. Oh well |
10-02-2019, 04:11 PM | #6 | |
10-02-2019, 07:11 PM | #7 |
Drives: 2012 Porsche 911 Turbo S Join Date: Jan 2017
Do you have traction control off?
IG: 2fast2nick
-- Current -- 2012 Porsche Turbo S - PDK - Basalt Black Metallic -- Past -- 2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101 2015 Mustang GT PP - Whipple Supercharger |
10-02-2019, 07:33 PM | #8 | |
Thank you Al Oppenheiser!
From Al O, on line lock:
10-02-2019, 08:30 PM | #9 |
Line lock lasts for 15 seconds and all it does is lock the front brakes.
It's totally up to you how long you want the burnout to last. Line lock helps you get the tires spinning good, then you can push the buttons on the steering wheel (middle one on each side) and it releases line lock so you will start to roll forward. Keep your foot in the gas and if you are going forward too fast just give it some light pressure on the brake and keep your burnout going as long as you want. Even at the drag strip you're going to want to roll out of your burnout like this. Don't just sit in one place... lay down some long stripes. |
10-09-2019, 04:11 PM | #10 |
Drives: 2018 Red Hot ZL1 1LE Join Date: May 2017
For a launch...surprisingly...there's launch control.
2018 RED HOT ZL1-1LE: Nav,PDR,Floor Mats
Built! |
10-09-2019, 08:07 PM | #11 |
Drives: '18 RH ZL1 1LE Join Date: Apr 2018
