Old 06-18-2018, 01:18 PM   #1
Tushar
Tushar's Avatar
Drives: 2016 2SS
Slow puncture and tire shop recommendation
Hi all,
I usually fill up my tires to 37psi. Every morning before I set off to work I see a pressure of about 34psi on three tires however the right front is always a little lower. In about 3-4 weeks of filling it, the right front shows a cold tire pressure of about 27psi.
I drive on the highway for about 20 mins to reach work, by then the three tires show a warm tire pressure of about 37-38 psi and the right front is at around 30psi.
So do I have a slow puncture? Do I need to get it fixed?
I live in the bay area in California. Please give me some recommendations for a good tire shop nearby. I also have Costco membership.
Thanks!
Dream Big and Work Hard....cos you never know when your dreams may come true!!
2SS Garnet Red
NPP
Automatic
Tushar is offline   Reply With Quote
Old 06-18-2018, 01:23 PM   #2
enzia35
Drives: '16 Garnet Red 1SS
Take it to a shop and let them figure it out. America's Tire is in CA.
'16 Camaro 1SS
'18 Miata GT
Old 06-18-2018, 01:27 PM   #3
torqueaddict
Drives: Tesla M3 LR-AWD [Former 1SS owner]
I'd guess you do have a slow leak. Have you inspected the tire? You should be able to see something unless it's on the inside wall. You can also try using some soapy water to look for bubbles. Could also be the valve. If it's not obvious, you'll need a shop to look at it. Even if you find it, you'll need a shop anyway, lol.
torqueaddict is offline   Reply With Quote
