05-07-2017, 05:50 PM | #1 |
Drives: 2014 Camaro Z/28 Join Date: Nov 2016
Just installed my wickerbill, doesn't seem right.
Look how low it is, this is on the highest setting. I think the lowest setting would make it almost non-existent.
You can also see the outer edges of it hangs below the OEM spoiler. I followed the GM instructions that clearly stated to have the template lined up with the BOTTOM edge of the spoiler. Is this how your guys looks?
2014 Camaro Z/28. Last Pre-Production car, #69. White without A/C, 1 of 4. 2008 Mercedes AMG C63 Longtubes, Intakes, Wheels, Coilovers, Tune 2006 Lamborghini Gallardo SE Gated Verde Ithaca Heffner 1000TTG |
05-07-2017, 06:12 PM | #2 |
Drives: 2015 Z/28; 1969 Camaro SS Join Date: Nov 2015
I believe that looks right.
05-07-2017, 07:07 PM | #3 |
199
Drives: like a granny Join Date: Apr 2013
no, rivnuts installed too low, unfortunately.
2023 Silverado LZ0 Duramax
2021 Shock SS 1LE A10 www.youtube.com/@DemonWorksPerformance Anderson composites coupon code : Demon |
05-07-2017, 07:09 PM | #4 |
Yep, I just checked mine. Looks close, but I think they may be a bit low. The second rivnut washer looks like it sits below the spoiler. On mine, that same washer is above the bottom edge of the spoiler. No one's gonna notice unless you tell them. I wouldn't worry about it.
2015 Z/28
A/C and audio |
05-07-2017, 07:11 PM | #5 |
YOLO Z/28
Drives: 2014 Z/28 Join Date: May 2016
Mines definitely higher. I dont have a pick with the OE wicker because the 2 Piece aftermarket one was my first upgrade.
2014 Red Hot Z/28, CTF car #39/69. HCI, Supercharged, boltons.
2006 SRM GTO, exhaust, VMR V701 wheels (SOLD) 2002 Bright Red Trans Am WS6: HCI, exhaust, tune, Konis, UMI sways, LCAs, Track bar, STB, 2" boxed steel SFCs (SOLD) |
05-07-2017, 07:25 PM | #6 |
Instagram: Sangstah
Definitely looks a bit low
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
05-07-2017, 07:31 PM | #7 |
YOLO Z/28
This is a picture of mine. The lower part of the dog ear sits flush with the base of the spoiler and doesn't hang low like yours. If all you care about is looks, I wouldn't worry. If you were actually trying to achieve more stability around the track, then you probably won't get the same down force.
2006 SRM GTO, exhaust, VMR V701 wheels (SOLD) 2002 Bright Red Trans Am WS6: HCI, exhaust, tune, Konis, UMI sways, LCAs, Track bar, STB, 2" boxed steel SFCs (SOLD) Last edited by YOLO Z/28; 05-07-2017 at 07:52 PM. |
05-07-2017, 07:33 PM | #8 |
Drives: Z/28 Join Date: Oct 2015
I cheated and moved the template up slightly when I installed mine.
05-07-2017, 07:52 PM | #9 |
YOLO Z/28
Haha I would've done the same if my car hasn't already had the wicker installed!!!
05-07-2017, 08:00 PM | #10 |
Comparing mine to all the pics from GM on the web, it looks like I indeed installed it correctly.
But imo it seems the OEM install is a bit low, I'd like it up about 3/16 of an inch from where GM recommends.
05-07-2017, 08:06 PM | #11 |
YOLO Z/28
Interesting. Mines a CTF car like yours, but had the wicker installed from the factory by GM. Whoever put mine on didn't follow the instructions correctly lol
05-07-2017, 08:43 PM | #12 |
Followed the instructions on mine and it came out this way but remember cheating it just a very small amount so wicker bill did not stick down below other spoiler, but again small incremental move what I remember.
68, 69 & 2015 Z/28's
68 Z/28 Restoration Thread on Team Camaro http://www.camaros.net/forums/showthread.php?t=182584 |
05-07-2017, 08:59 PM | #13 |
Drives: 2015 Z/28 Join Date: Jun 2011
I think you installed it correctly with regards to the instructions, but I cheated it up like D2M...
05-08-2017, 09:20 AM | #14 |
Drives: 2018 ZLE Join Date: Jul 2014
Here is mine.....factory installed.
