04-13-2021, 12:09 AM | #15 | |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
As long as it's not as stupid as RX-8 where the coolant overflow relief dumps right onto the electric power steering connector, you are fine.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
04-13-2021, 09:38 AM | #16 | |
Thank you Al Oppenheiser!
This is why you check and fill when cold. There's a half-moon circular cutout in the bottom tank (visible in that manual page I show above). Fill to half-way when cold, but anywhere in that circle should be fine, IMO. If you're way over-filled (i.e. bottom tank completely full), then expect a bit of coolant to come out when the car heats up. The only harm it will do is make a bit of a mess when it overflows a bit when hot. |
04-13-2021, 11:23 AM | #17 | |
Drives: 2018 Hot Red ZL1 Join Date: Nov 2010
Sent from my moto g(7) power using Tapatalk
04-14-2021, 08:21 PM | #18 |
04-14-2021, 08:48 PM | #19 |
The point is to top it up when cold.
04-14-2021, 08:55 PM | #20 |
Fill the top reservoir to the top and the lower reservoir or tank halfway like the manual shows when cold. It’s not rocket science. Good luck.👍
04-14-2021, 10:04 PM | #21 |
I get that. But the manual (post #2) shows in step 4 to top it all off at the top tank and half at the bottom. Then let the car run with the top tank cap off and fill port cap off until the upper radiator hose starts to get home. Turn the car off. Put the cap back on the top tank and close the fill port for the lower tank and let the car cool down. Then inspect again to check the level. So my question was which hose are they referring there?
04-14-2021, 10:07 PM | #22 | |
04-14-2021, 11:20 PM | #23 |
The upper radiator hose going into the thermostat housing is the one the manual is referring to. Hope this helps you.
04-14-2021, 11:22 PM | #24 | |
The small house coming from the top tank into the radiator and the thermostat housing got hot Sent from my moto g(7) power using Tapatalk
04-14-2021, 11:25 PM | #25 | |
Drives: 2019 ZL1 Join Date: Mar 2019
Its not going to get hot until the car reaches operating temp and the tstat opens to let coolant through. Drive the car. |
04-15-2021, 01:08 AM | #26 |
Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
When I bought my '18 zm1 (non-1le) it had 32xx miles on it. I didn't know about the coolant level thing and prob a week after I drove it home I learned about it and it was the same as yours OP, about half way on top. didn't notice any performance issues on the 14xx mile drive from TX to AZ though. Bought some coolant at the dealership and topped it off. Put about 100 miles on it in a few small trips and it went down a hair. Topped it off again and its been full for the last 1300ish miles.
04-27-2023, 10:26 AM | #27 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
My top tank is full and bottom tank is pretty much empty. I know the bottom should be about half full so does anyone have any experience with this condition? Plan is to get a gallon of Dexcool 50/50 and fill the bottom chamber thru the service port per the manual. Just wondering if I might have something else going on. Also, while I'm at it, I plan to burp the IC lines as that's never been done that I recall.
04-27-2023, 12:40 PM | #28 |
376 cubic inches of fun
There's some bad advice in this thread that contradicts the OM instructions.
The upper tank is part of the pressurized system. Topping it off is essentially like topping off the radiator. The only way to do that without trapping air is to do it while coolant is being circulated. That's why the OM tells you to run the engine and top off once the thermostat is open. Only then you can adjust the lower tank level. |
