03-29-2021, 07:06 AM | #15 |
Drives: 2018 Chevy Camaro ss 1LE Join Date: May 2020
04-03-2021, 12:51 PM | #16 |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
Check your oil pan to see if there is any oil residue or dirt stuck onto the sides and/or bottom. I have had 2 separate oil pan bolts become slightly lose (felt about finger tight when I put a socket on them, one on each side) which caused a bit of oil seepage at different times about a year apart requiring me to add over half of a quart of oil each time after tightening them back up which stopped the oil consumption both times.
Maybe it was caused by the vibrations from using curbs on tracks but it does not seem to be a common issue with the 6th gen Camaro. https://www.camaro6.com/forums/showthread.php?t=567130 |
04-05-2021, 06:51 AM | #17 | |
Will ck it out |
04-05-2021, 07:51 AM | #18 |
I think mine is basically the same as yours. It hasn't been to Sebring, but it definitely uses a lot of 0W40 oil in a day of hard pulls.
'20 ZL1 1LE A10,
04-09-2021, 07:33 PM | #19 | |
At Sebring you are to the floor, most of the time. I had over half a tank of gas, and almost ran out of gas, in a 25min run Car seems fine, runs perfect So I’ll ck oil before I start it, when I return to Florida |
04-09-2021, 10:05 PM | #20 |
Drives: 2021 2SS 1LE Join Date: Aug 2020
Just had my first track day at CMP with 2000 miles on the odo. Didn't consume any oil prior to this. Three, 20 min sessions with 5 WOT sections to 100+mph. Used 1/3 quart of oil. Is that good?
04-10-2021, 11:14 AM | #21 |
04-10-2021, 12:14 PM | #22 | |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
2nd vote for this. My oil pan bolts were working loose after about 2 years. Tightened them and haven't had any seepage since. As for oil consumption, as of 40K miles and LOTS of track days, I burn 0 during an event. I've never added more than 1/4 qt between oil changes. OP - that much consumption during ONE event is concerning. Modern engines just don't burn oil. If they do, something is wrong. I'd find a shop (or DIY) to perform a compression check.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
04-10-2021, 10:02 PM | #23 |
Drives: 2000 Toyota Altezza Join Date: Dec 2018
04-11-2021, 08:18 AM | #24 |
Drives: 2020 Camaro SS 1LE Join Date: Jun 2020
2020 SS 1LE with ~3000miles on it when I ran CMP this past winter 4 x 20 minutes sessions, 0w-40 Mobil1 ESP....no oil burning. After that, a weekend at VIR, no oil burning.
04-11-2021, 09:27 AM | #25 | |
Guys are telling me they are doing 2:23s stock I think I can get my times down a few seconds, but not 7sec I’m going to Chin at Sebring end of the month, we will see what happens |
04-11-2021, 09:58 AM | #26 |
Drives: 2017 SS 1LE Join Date: Mar 2017
Some don't always tell the truth, bench racing
If your going the 24th, might see you if I don't have a conflict. |
04-11-2021, 11:35 AM | #27 | |
PB is a 2:28 on OEM tires. I'll be there with NASA on 4/17-18 to see if I can shave a few more tenths...
2017 HBM SS 1LE
04-11-2021, 12:47 PM | #28 |
Thread Tools | |
