Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 07-05-2020, 09:31 AM   #1
kingofthelv
Drives: 2014 1SS/RS
tire size?
i am getting some 20X10 on the front and 20X11 on the back. i have a 2014 ss.
what tire size would fit with these rims? what are the best tires as well?
kingofthelv is offline   Reply With Quote
Old 07-05-2020, 10:46 AM   #2
Vegas Bound
Drives: 2013 Sparkly Red One
Check out the sticky post.
Vegas Bound is offline   Reply With Quote
Old 07-05-2020, 10:50 AM   #3
kingofthelv
Drives: 2014 1SS/RS
would a 285/30/20 on the front or 305/30/20 on the back work?
Old 07-05-2020, 10:52 AM   #4
Vegas Bound
https://tiresize.com/comparison/
Old 07-05-2020, 11:02 AM   #5
kingofthelv
Drives: 2014 1SS/RS
i am asking a question and i want a answer
Old 07-05-2020, 02:28 PM   #6
Avenging Orange
Avenging Orange's Avatar
Drives: 2010 Inferno Orange 2SS/RS
Then go find it. The information is right here.
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!!
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
KICKING CANCERS ASS SINCE 2015!!
Avenging Orange is offline   Reply With Quote
Old 07-05-2020, 02:32 PM   #7
102SS
waiting at the tree
102SS's Avatar
Drives: SIM 2010 2SS/RS A6
Yes thats the stock ZL1 sizes.
Thats what I have on my car.
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28)
2009 Pontiac G8 3.6L the DD
102SS is offline   Reply With Quote
Old 07-05-2020, 02:37 PM   #8
lemontwist
lemontwist's Avatar
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled
lemontwist is offline   Reply With Quote
Old 07-05-2020, 03:25 PM   #9
Vegas Bound
You can WANT in one hand and CRAP in the other and see which one fills up fastest.
You were given the tools to find the answer yourself. Get at it.
Old 07-05-2020, 03:40 PM   #10
kingofthelv
Drives: 2014 1SS/RS
i am just asking a simple question but y’all want to act like an ass i got my answer. the camaro 6 people give answers
Old 07-05-2020, 04:49 PM   #11
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
6 gen cars use 30 series tires, 5 gen used 35 series. In my opinion the 30 series look too small on the 5th gen. This forum has been around for 11 years, a wealth of information has been banked here, searching will give you a lot more information to form a decision.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers, rotors & pads, BMR Trailing & Toe Arms, rear cradle & diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 whls, 275/40/20 & 315/35/20 tires, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console & Grant steering wheel.
flht99b is offline   Reply With Quote
Old 07-05-2020, 07:24 PM   #12
kingofthelv
Drives: 2014 1SS/RS
i will just go with the 35 instead of the 30 in that
Old 07-14-2020, 11:04 AM   #13
Christian_UA
Drives: Hennessy HPE 600
I'm owning a 2012 Hennessy HPE 600. At Hennessy there were HURST rims installed, the original rear tires (275/40) went to the front, on the rear Pirelli PZero 305/35-20 were fitted.
Now I need new tires, but 305/35-20 aren't available anymore, at least here in Ukraine.
The question is to change for 275/35-20 and 305/30-20 or to use 275/40-20 (front) and 315/35-20 (rear). The tire dealer over here isn't sure if 315 instead of 305 would fit the rims and chassis.
Can anyone help ? Thanks !
Christian_UA is offline   Reply With Quote
Old 07-15-2020, 08:03 AM   #14
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I have 20x10 front with 275/35/20 and 20x11 rears with 315/35/20 and am lowered 1.25 all the way around. I also had the MPSS 335/30/20 on the rear but took them off and went back to 315 because the fender gap was too much for my liking. They will fit thouhg depending on the wheels offset. Good luck
1JEWLDSSRS is offline   Reply With Quote
