12-23-2017, 01:04 PM | #1 |
Drives: 2013 2LS inferno orange camaro Join Date: May 2017
Need help Brake job on a 2013 Camaro 2LS.
I'm trying to replace the front rotors and pads on my V6 2013 Camaro 2LS.
I've read on here and have seen YouTube videos that say that you have to replace the caliper bracket bolts and the caliper slide bolts because they are torque to yield. Can somebody confirm that I need to replace them on my model Camaro? I went to two dealerships by me and they have both said no and in the parts department they said that if they needed to be replaced that it would say so when they looked the up. I'm new to the 5th Gen Camaro and to the board but not to Camaro's. I've owned Camaros all my life. Thanks, Chris |
12-23-2017, 08:38 PM | #2 |
I didn't replace any of those bolts when I changed the rotors and pads in my LS.
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
12-23-2017, 09:06 PM | #3 |
'Maro
Drives: 2015 SS 6.2L Auto 2SS Join Date: Sep 2016
I too have replaced my pads and rotors and reused the old bolts. I've done that on several vehicles and from what I've seen here everybody here has differing opinions. The bolts are inexpensive if you want to do it absolutely the correct way, but I'm not worried about my situation
2015 SS 2SS Auto 93 SCT Perf, Kooks LTH & HFC MBRP Axleback Muffler Delete "Z/28" Spoiler and Grille OEM ZL1 wheels 285/305/35R20 BFG G-force Pro Comp 2
12-23-2017, 09:28 PM | #4 | |
Drives: 2014 Ashen Gray Convertible Join Date: Apr 2017
Chris, as others have stated, you will find different opinions regarding the caliper bolts. HOWEVER.... the two dealerships that you went to and were told they did not have to be changed is WRONG! These bolts are "torque to yield" and Chevrolet has them as being changed with each use. If folks don't want to change them and they feel comfortable with that then so be it. My self I always try to use OEM parts and if the bolts are torque to yield bolts then I will spend the few extra dollars and change them. Good luck and Merry Christmas.
12-24-2017, 01:35 PM | #5 |
Drives: cars Join Date: May 2011
If you reuse then add blue loctite.
12-24-2017, 01:56 PM | #6 |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
V6 models only
Caliper to Bracket Sliding pins can be reused. Sliding Caliper (Front and Rear) Torque to 20 Foot Pounds Caliper Mounting Bracket to hub bolts Torque to yield. Step 1,Torque to 30 foot pounds Step 2, Tighten an additional 90 Degrees. This is from my Chilton's 2010 to 2015 Camaro Book
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
12-24-2017, 02:14 PM | #7 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
I reused and added blue loctite...
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
