04-27-2017, 09:50 PM | #15 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
if one goes with sport drive mode, does one have access to full PTM or partial choices only and if so which ones? thx
04-27-2017, 10:10 PM | #16 |
Drives: 2017 1SS/1LE Join Date: Sep 2016
04-27-2017, 10:15 PM | #17 |
So if you prefer Sport than you run with no nannies or all nannies or comp mode? Could you clarify what mode choices are there (if any) in Sport. Thx!
04-27-2017, 10:48 PM | #18 |
Drives: ZL1 1LE Join Date: Oct 2016
Just an FYI, as I recently discovered this, even in track mode the exhaust valves will close at certain times, like 6th gear freeway cruising speed.
04-30-2017, 08:05 PM | #19 |
Drives: '20 ZL1 M6 Join Date: Apr 2017
I've heard there is a fuse delete to keep the valves open. Which fuse, and will it throw a code?
Mal
Ft. Lauderdale, FL '20 Camaro ZL1 M6 '22 Kawasaki ZX-14R |
04-30-2017, 08:19 PM | #20 | |
Drives: 2017 Hyper Blue 1LE Join Date: Dec 2016
I don't think you can take all of the nannies off unless you're in Track, PTM and then only in certain modes. This all should be in the HP supplement. |
04-30-2017, 08:35 PM | #21 |
Personally, I'm ok with it closing in 6th gear freeway speeds, helps with drone. I don't plan on removing the fuse, though if you wanted to I'm sure you could find out the correct one with a search on here.
04-30-2017, 08:41 PM | #22 |
Drives: E46 S54 race car, 964C2 Join Date: Feb 2017
04-30-2017, 11:09 PM | #23 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Pull fuse #51 in the engine bay to disable the NPP. Drone is non-existent on the highway and I don't even have the secondary cats and it is still fine.
05-01-2017, 08:06 PM | #24 |
I drive in track mode. Is there any benefit in sound by pulling the fuse or is the exhaust always open in track mode?
Mal
05-01-2017, 08:12 PM | #25 |
You can decouple steering and exhaust from the "mode" selector by the shifter. I leave the suspension to be adjusted by the mode selector and lock steering in touring and lock exhaust in track. So regardless of what suspension setting I switch to, steering and exhaust stay the same. This is a REALLY awesome feature most manufacturers don't offer, the ability to hold settings between ignition cycles.
05-01-2017, 08:59 PM | #26 | |
Mal
05-01-2017, 09:02 PM | #27 |
I have my exhaust fuse pulled, can't tell any difference. Keep meaning to reinstall it for those early morning starts (for my neighbors sake!)
05-01-2017, 09:07 PM | #28 |
