01-10-2019, 12:30 PM | #15 |
Ceramic Coating?
01-10-2019, 12:40 PM | #16 |
Drives: 2016 Camaro SS Join Date: Sep 2018
01-10-2019, 01:29 PM | #17 |
Drives: 21 SS Join Date: Oct 2017
Stock plugs, not coated but I do have wire sleaves that I bought because I was scared of plug wire issues based on these forums. 12,000 miles later with headers and no issues.
01-10-2019, 04:28 PM | #18 | |
Drives: 2018 2ss 1le Join Date: Jan 2018
I will revisit wrapping the header by the starter but only If I can do it without removing anything... I looked to me like it would be fine the way it is.... I wonder is it a bigger issue on 2' headers or it doesn't matter cause its close to the collector
2018 2ss 1le roto fab dry, Stainless works 1 7/8 lt to 3'" x pipe with highflow cats to stock npp, soler 95mm t/b, edelbrock 2300, LT4 fueling , jms bap and dsx flex fuel, 618/620 on e45 rwhp
Jannetty Motorsports tuned |
01-10-2019, 08:26 PM | #19 |
Drives: 2018 1SS 1LE HBM Join Date: Jul 2014
So what do you guys think....I looked in to heat shield products spark plug boot heat shield sleeves, their pricey at $110 for 8 and also the heatshield products exhaust and header wraps. Not crazy about the look of wrapped headers. But their marketing is catchy especially the physics and explanation of the effects of the product. What are you guys using?
01-10-2019, 08:32 PM | #20 | |
01-10-2019, 09:11 PM | #21 |
Drives: 2018 SS 1LE Join Date: May 2018
My headers were ceramic coated and I believe it’s with the cost up front with heat
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune https://instagram.com/corn_sauced?ut...d=o0ako89uurwl |
01-10-2019, 09:17 PM | #22 |
I bought spark plug boots on amazon and had to modify them
but they look like they will work fine https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
01-10-2019, 11:38 PM | #23 |
Drives: SS 6 speed of course Join Date: Jan 2016
Bumped on other thread the header and starter wrap.
01-12-2019, 12:30 AM | #24 | |
I did swain tech ceramic coating. no issues but its only been 1 summer 9000 miles. My 17 starter had a heat shield. i believe the 16s didn't. http://swaintech.com/race-coatings/ cost me $350. they are local so i dropped them off. they are the best. its not paint like the other places that say they are ceramic.
01-12-2019, 02:22 AM | #25 | ||
Drives: 2018 Camaro 1SS Join Date: Jun 2018
Swain tech are one of top coating company in my book. Price sounds good compared to jethot coating.
2018 1SS 6MT: SOLD
01-12-2019, 07:16 AM | #26 | ||
Drives: 2017 ZL1 6MT Join Date: Feb 2018
I also initially installed the kevlar spark plug wire sleeves. But they looked horrible in an otherwise clean engine bay so I took them off.
2017 ZL1 Arctic Blue Metallic / 6MT / sunroof / NAV / PDR / RotoFab CAI + dry filter / Tony Mamo TB V1 / Skip Shift Eliminator / Hurst Short Throw Shifter / ZL1 floor mats / Dead Pedal cover (to match other pedals) / ARH Catless 1-7/8" headers + ARH X-pipe + AWE Touring Axle-Back / Diode Dynamic smoked side markers / American Authority tow hook
01-12-2019, 07:18 AM | #27 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
1) keep your eye on the plug wires, they can and will move over time. Make sure a plug wire never, ever touches a header pipe. 2) The stock plug wires are fine, but wire sleeves are a good mod and worth the money. They prevent direct contact between pipe and wire and keep exhaust heat from degrading plug wires over time. 3) Coating your headers is a great idea, dissipates heat more quickly and lowers underhood temperatures during cool down. Coating and wire sleeves together are well worth protecting your plug wires and engine compartment generally from external heat. 3) Do not wrap your headers. Coat them. Wrapped headers are not nearly as effective, can lead to hot spots on the pipes, can facilitate rust, and, IMO, look like crap.
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
01-12-2019, 08:00 PM | #28 | |
You can only YOLO once.
Drives: '16 2SS & '15 Subaru Forester Join Date: Jan 2016
Starter - I got the DEI starter blanket but my headers (Kooks Long-Tube 1 7/8") came with some heat tape for it too. I went with the blanket because I have already experienced the starter getting heat soaked with the OEM exhaust manifold after a couple of 20 minute track sessions so it was already something I intended to address. Plug Wires - I have OEM wires with DEI Boots on.
2016 Camaro 2ss
-Summit White / Ceramic White -8A, NPP, MRC, Ceramic White package plus knee pads, black bowties. -1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns. -1st Car to have the 6LEDesigns Blade Spoiler. -Borla S-Type w/ custom H-Pipe -Procharger P-1X Stage 2 Last edited by bpang1234; 01-14-2019 at 11:55 AM. |
