12-13-2019, 10:03 AM | #5125 | |
Drives: 1999 Camaro SS M6 - SBE LS1 Join Date: Jun 2018
I always lament the loss of options, but especially powertrain ones. While he is half-correct that a transaxle doesn't exist to hold the LT2's torque, Audi/Lambo have had a manual ME car that can handle their V8 and V10 offerings...note this also includes a convertible. This negates his tunnel structure argument, not to mention his linkage argument. Porsche uses cable linkages effectively, and while correct on flat engine design, he leaves out that they still require the cables to go up at the backbone of the P car chassis and over the top of the engine. What he doesn't mention is the LT2's gap below the intake - room enough for a cable set with a little creativity.
1999 Camaro SS 6M - SBE LS1
1963 Corvette GrandSport - ZZ502 4M 2017 Denali 1500 6.2 2017 Yukon Denali 6.2 |
12-13-2019, 10:04 AM | #5126 | |
Drives: 1SS, A8, MRC, NPP, Blade Spoiler Join Date: Jun 2010
Ford added a harmonic balancer to their Voodoo engine to help with the vibrations, and Chevy could do the same. But, that also adds mass back to the rotating/reciprocation assembly, which reduces the main benifit of an FPC engine, namely quick to rev. BUT, as I explained before, Ford already had to add the counterweights back to the crankshaft due to intake limitations that changed the firing order. So, for them, adding a harmonic balancer wasn't a big deal. Just so folks know, the thoretical limit to an inline-4 cylinder engine is 2.0L. BUT, we see tons of I4's with displacements higher than 2.0L. That's because the engines have a harmonic balancer or balance shaft added. So, it's not as impossible as most folks think to build a large FPC engine. It's just a question of how much mass are you going to add back to balance the second order vibrations, and is it worth it? If you are building the worlds best super car like Ferrari and others, they want to go with the most exotic engine, no matter the cost. So, compromising is frowned upon. Just keep the diplacement manageable, and add a bunch of boost. For a mass produced Chevy, adding a little mass (but not nearly as much mass as the Voodoo's heavy counterweighted cranshaft), is probably a compromise they are willing to make. And it won't make nearly the difference to the engines ability to rev quickly like the Voodoo. AND a big plus here is that with a harmonic balancer, the engine will have much less NVH, not only for reliability, it will make the engine a lot smoother. |
12-13-2019, 10:09 AM | #5127 | |||
Drives: 2013 C6Z06 Join Date: Nov 2016
There is not 1 person on this forum that has ever been to 180mph in their Camaro on a road course, so we know you are lying, no thinking involved. Quote:
12-13-2019, 10:17 AM | #5128 | |
Drives: 21 Bronco Join Date: Jun 2012
12-13-2019, 10:54 AM | #5129 | |
Retired from GM
Drives: 2017 Camaro Fifty SS Convertible Join Date: Mar 2017
A8 | MRC | NPP | Nav | HUD | GM Performance CAI | Tony Mamo LT1 V2 Ported TB | Kooks 1-7/8” LT Headers | FlexFuel Tune | Thinkware Q800 Pro front and rear dash cam | Charcoal Tint for Taillights and 3rd Brakelight | Orange and Carbon Fiber Bowties | 1LE Wheels in Gunmetal Gray | Carbon Fiber Interior Overlays | Novistretch bra and mirror covers | Tow hitch for bicycle rack | |
12-13-2019, 10:55 AM | #5130 | |
In my opinion, an FPC engine will fit just fine in the mid-engine layout. If you look at the rear hatch with the window in it in the C8, there is tons of room on top of the engine for a dual intake setup. In fact, the extra room is what gave Chevy the ability to add a highrise inake to the LT2. Also, and FPC engine has a much smaller crankcase, so the lower part of the engine is much smaller. And I am sure that the engine bay of the C8 was specifically designed to handle all power plants they have planned in the future, including an FPC with a TT setup. |
12-13-2019, 10:57 AM | #5131 | |
Retired from GM
12-13-2019, 10:57 AM | #5132 | ||
But in regards to the bold, the GT350 came out so early in the S550 don't you think Ford had the Voodoo planned well in advance and would have anticipated packaging as well? |
12-13-2019, 11:03 AM | #5133 | |
12-13-2019, 11:16 AM | #5134 | |
Also, a mid engine layout with a hatchback design will always give you a taller engine bay than a front engine car (because you have to be able to see over the engine bay in a front engine car). |
12-13-2019, 11:24 AM | #5135 |
You will also note that the leaked CAD drawing of the TT engine has a dual intake setup. Which would imply that this is a proper FPC engine.
12-13-2019, 11:26 AM | #5136 | |
12-13-2019, 11:26 AM | #5137 |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
From the cross sectional pictures I've seen, the LT2 sits low, but not quite lower than the top of the tires.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
12-13-2019, 11:47 AM | #5138 |
Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
Sides might be a little tight, but I'm sure that was already taken care of earlier in development when possibly engines were being considered.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
