11-04-2017, 08:38 AM | #561 | |
Drives: 2015 Mustang GT PP M6 Join Date: Jun 2016
My shitty setup should be in the ballpark of 750-800whp (on a dynojet) on plain jane 93 and 12lbs(711 was on a mustang dyno and stopped at 7500 before I upgraded my opg/cs) The only real issue with FI and the coyote is the shitty crank sprocket an oil pump gear. Swap those $300 parts and you can safely rev to 8k+ And before the Troll posts, you can call it that if you want but I do enjoy reading on your cars from time to time and asking questions when I have to Edit: And fyi this setup is about 2 years old, over 23k miles daily driven
'15 GT PP M6 763RWHP @ 8100RPM 3740lbs
3.2LC KB, ID1000, Boundary OPG, TSS CS, KB BAP, SCT X4, Palm Beach Tuned, Kooks 1 7/8 Catted LT's, Magnaflow Comp. Cat-back, Mantic Twin Disc, MGW Short Throw, Maximum Motorsprots CC Plates, BMR Cradle Lockout, Eibach Pro-Kit, Proj. 6GR 19x10 ET35 19x11 ET50 Lumar 35% Tint, UPR Floating Pony, MMD Decklid, BlackVue650GW Dash Cam |
11-04-2017, 08:51 AM | #562 | |
2016 NFG 1SS A8
11-06-2017, 06:29 PM | #563 |
I have not touched my stock fuel system on my LT1 and I'm well past 600 at the rear wheels and with traction can be in the low side of 10's. The old school fuel style on the 5.0 does make the stock system more forgiving for sure, but it comes with its own line of issues. Dollar for dollar the 5.0 does not seem to push HP numbers like the LT does. That's using the same dynojet with the Eddy Brake system and basing gains off of stock number to post modified numbers as a comparison.
2016 2SS/Hyper Blue/M6/NPP/Navi
Forged pistons Custom cut Brian Tooley Cam SW long tube headers 3" stainless mid pipe - Secondary Cat delete - High flow cats Port and polished heads-Double valve springs-platinum lifters & push rods Cam phaser limiter - DOD delete P1SC-1 Pro Charger 3.7 pulley Stage II intercooler 667rwhp 577ft lbs Last edited by Chevy71; 11-06-2017 at 09:22 PM. |
11-06-2017, 09:21 PM | #564 | |
I have not done a coyote nor do I know of a coyote making big power by just tuning the stock injectors up. Even the small roush kit comes with new injectors and a new rail. While the sequential injection is easier than direct injection, I don't think it makes as much power and they added those dang charging valves back in the intake to balance out flow which is just another part to hassle with. I have not seen first hand any S550 or S197 sail on by the LT with alike mods both boosted or N/A. Actually N/A the coyote seems to really fall behind the LT and Hemi both. They still build rpm so slow still too, Ford clearly seen this and tried fixing it by going with the updated crank for the 350's to improve rev. speed. My experience each engine gains power from different types of adders but the coyote never seems to have the upper edge in anything I've done personally or seen. Actually it certainly gets better gains from headers than the LT does. It seems to hit the same limits an LT does just requires a little more to get it to those power levels. That's my personal experience which ultimately means nothing lol. My car is making over 750 at the crank on 7psi and that's stock LT1 fuel system, stock muffler, stock intake manifold, and stock throttle body. To be fair, my cam does have a larger fuel lobe for the HPFP. Let's not talk about doing all the cams in the coyote and that crazy phaser system they have lol
Forged pistons Custom cut Brian Tooley Cam SW long tube headers 3" stainless mid pipe - Secondary Cat delete - High flow cats Port and polished heads-Double valve springs-platinum lifters & push rods Cam phaser limiter - DOD delete P1SC-1 Pro Charger 3.7 pulley Stage II intercooler 667rwhp 577ft lbs |
11-07-2017, 06:24 AM | #565 | |
2. I'm sorry if I made it seem that we were making power on the stock injectors. They most definitely will not support any kind of Forced induction, which is why theyre included in about any kit you purchase aside from the cheaper "tuner" kits. 3. The "common", which arnt that common, engine failures 9 times out of 10 is the stock oil pump gears letting go. They don't do well in high rpm or high power applications. As long as you keep the revs under 7500 and arn't trying to make more than 800 crank you're generally pretty safe. The other issue some others are having is wrist pin problems. But that crowd is usually on e85 or some type of race fuel, really pushing the boundary for the stock motor. Theyre in the 800-900whp range. If the tune is spot on, the pistons do fine. 4. Forged crank and forged rods. The rods are actually sinter forged and are the next weak link when you start making closer to the 1000 hp mark. 5. agreed. theres no one running stock injectors making big power. and DI > PI when it comes to forced induction. 6. The only way you're still dealing with those valves is if you're running a turbo and you keep the stock intake manifold or you're running a centri blower. All the Positive displacement blowers(roots/twin screw) you cap off the plugs to them and throw the intake in the trash. 7. Agreed. the n/a coyote is horrible. I came from pushrod motor prior to this modular one in the mustang. The partial throttle around town low rpm response was awful. I missed my torquey pushrod v8. However, Kenne bell fixed my partial throttle low rpm issue 8. rpm climbing slow? a bunch of factors play into this, the coyote just has more of them to climb? dont really know what you're saying here. I can't say for sure why ford wanted to try the flat plane crank, they sound amazing but the engine literally wants to vibrate apart. The reason the coyote has the upper hand in Forced induction is you don't have to open the motor to swap pistons and drop a fat dime on fuel upgrades to get you there. Usually a BAP and injector is all you need to make into the high 700-800whp range. 9. Can't comment here, other than factory cats are bullshit. But i do suggest you pop on over to your sister forum (mustang6g) and checkout the forced induction section if you think i've got reason to lie about anything.
11-07-2017, 10:37 AM | #566 | |
2016 NFG 1SS A8
11-08-2017, 07:32 PM | #567 |
Fair, my lobe certainly allows the HPFP to move more fuel and pressure, but everyone will tell you the fuel runs out on the stock injectors and the stock HPFP in the mid to high 500rwhp range and that at a minimum you have to install LT4 fuel parts for anymore gains. Which I never have thought was true and am not running any of it on mine.
11-08-2017, 07:42 PM | #568 | |
I put pistons in mine last month only because I'm looking to go with much higher boost this winter in the off time. I could have easily been 700whp with my set up without changing fuel or dropping pistons, I'm only on 7psi and almost there now. My issue with the smaller pulley was IAT's and with the miles I drive didn't want to deal with meth injection to help drop the temps. For the most part I would have been alright, but those few times it gets hot are no good. With my next phase I'll clear that up and I knew the stock pistons wouldn't be able to handle 15psi for long lol. I think a lot of people with the LT1 are following the mass too much and not actually looking into the details haha I'll try to check out the sting forum and see what they have going. I struggle to keep up with this on and the vette forum as it is now though
11-09-2017, 05:22 AM | #569 | |
I've been considering running meth as well on my daily. I honestly dont care much for the additional power itll make, im making enough for a normal street radial anyways, i just want my blower to sing. You can't tell shes supercharged unless you notice the whistle at low rpm light throttle. Other than that, no whine!! And I honestly didn't know the LT1 had it in it to run high 600's at the wheels with FI. The times I pop over here and read about you guy's setup theyre usually only netting about 100-150 over stock putting them around 550whp maybe touching 600.
11-09-2017, 09:27 AM | #570 |
Drives: Summit white 1le ss Join Date: Feb 2017
Meth helps out a lot but now pushing the limit so time to go forged
11-09-2017, 09:48 AM | #571 | |
2016 NFG 1SS A8
11-11-2017, 12:46 PM | #572 | |
