05-24-2020, 10:17 PM | #1 |
Hot Camaro
NPP alternative?
EDIT: I was not clear with my original question, so I'm updating this post to be more on point. Original post remains below...
In my search for a car, there are a number of them that are "close" to what I want but are not factory-equipped with NPP. What alternatives to an NPP exhaust are out there that will give me a nice sound without being overbearing? If I were able to get NPP, I would make use of the stealth mode because I don't want it to be overly loud in many situations. So, my search here is for something that would give me a nice tone that would be less harsh at least while not hard on the throttle (coming home, for example, I wouldn't want to be rumbling down my street) since it may be an exhaust with a "constant setting". --------------------- What aftermarket options are there to richen the exhaust tone without being overbearing? I’m looking for a seemingly unheard of combo of options and am wondering what some good options are if I can find NPP on the car I buy. I like the idea of the Stealth Mode and will likely use it “enough” that a stock exhaust would be perfectly fine. But for those times when I’d like to hear it a bit more... well... Ideas ? Last edited by ember1205; 05-26-2020 at 10:02 AM. |
05-24-2020, 10:21 PM | #2 |
Drives: 2018 Camaro V6/RS Join Date: Nov 2018
What kind of Camaro do you have?
05-24-2020, 10:22 PM | #3 | |
Drives: Chevy Camaro Join Date: Apr 2020
05-24-2020, 10:26 PM | #4 |
Hot Camaro
05-24-2020, 10:30 PM | #5 |
05-24-2020, 10:35 PM | #6 | |
Hot Camaro
05-24-2020, 11:12 PM | #7 |
05-25-2020, 01:09 AM | #8 |
i like my Flowmaster American Thunder 817746
05-25-2020, 09:10 AM | #9 |
Drives: 86 Camaro IROC LG4, 16 Subaru WRX Join Date: Dec 2019
Man, all these people wanting to change shit. Still in my first week and get goose bumps when I cold start, even in track mode. I Giggle when I switch to track mode right before going into a longer tunnel.
The 2SS is a rolling work of art and love. Wanting to change her before you buy her is like scheduling been surgery for a supermodel you haven't started dating yet.
Joshfucious say: The lone tree in the distant mountain always looks taller... when the grass is mowed.
(Yes, I know my IROC is not a 5th nor a 6th gen. I'm here as I am thinking about a newer convertible and I know from experience most of the Camaro forum members are helpful and understanding.... right?!?) |
05-25-2020, 09:13 AM | #10 |
Drives: 2019 SS Join Date: Apr 2020
One word......Borla.
05-25-2020, 09:17 AM | #11 | |
Hot Camaro
05-25-2020, 11:56 AM | #12 |
Any good quality aftermarket exhaust system will be good to put on the car. NPP is a nice optional exhaust but if you are planning on changing it then the aftermarket is the way to go if you buy an SS with the regular exhaust!
05-25-2020, 12:09 PM | #13 |
Hot Camaro
I am only looking at change-out options in the even that the car doesn’t have NPP. If NPP equipped, no changes.
05-25-2020, 12:29 PM | #14 |
Drives: 2016 Summit White Camaro SS (2SS) Join Date: Oct 2016
I got a 2016 SS without NPP. And was in the same exact boat as you describe. QTP was high on my list but pricey. I also considered the Borlas but, again, pricey. I decided to gamble on low cost and went with MBRP axle backs. They're perfect.
Now, keep in mind, non-npp is two pipes out the back and many of the aftermarket options are four. That was fine with me because the stock valance/diffuser is ugly as sin. So, when I went to put on the MBRPs, I also swapped out the diffuser. Still a lot less expensive than the QTPs and Borlas. |
