05-17-2020, 10:14 AM | #15 | |
I would recommend ctek, here’s an example. https://www.amazon.fr/CTEK-MXS-5-0-E.../dp/B00DEID79G
05-18-2020, 10:34 AM | #16 | |
Drives: gas powered Join Date: Jan 2019
Double check the Hertz as well. We use 60 hertz in North America...I think some EU countries use 50hz. I would just buy one in France. There has got to be more cars with 12V batteries than just your Camaro.
05-18-2020, 02:08 PM | #17 |
Drives: Canadian 2019 BLACK ZL1 Join Date: Feb 2020
Hi guys Thanks for your answers ... thé ctek was thé one I saw... but i would like to be sure it’ll work with the camaro battery...
So ctek is ok in voltage ampère or hertz ? Thanks for your help guys.... |
05-18-2020, 02:23 PM | #18 | |
Good luck!
05-18-2020, 02:35 PM | #19 |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
Ugh - CTEK is the worst. It matters not one iota that it's a "Camaro" charger or GM rebranded product. It's a 12V trickle charger - you are paying for programming and durability, period
Try one of these, you will never go back to anything else https://www.amazon.com/gp/product/B0...rch_asin_title |
05-18-2020, 03:05 PM | #20 |
05-19-2020, 01:33 PM | #21 |
Euhhh so now what should I take ?
Maybe advices from those cho have one ? I still don’t know if I get a french or us battery... Thé decision will be Made on tomorrow ... |
05-19-2020, 02:50 PM | #22 | |
Hope this helps!
05-23-2020, 03:32 PM | #23 |
05-24-2020, 01:58 AM | #24 |
Drives: bmw m3 Join Date: May 2020
charging the dead battery would be a great option unless it is in function.
or else purchasing a new battery will be good choice try out deep cycle battery it has long life and don't need charging in very short time. I have found this guide which has best deep cycle battery list |
05-24-2020, 03:23 AM | #25 |
Great guide thanks ... only 11 tested... but that gives an idea
05-24-2020, 07:57 AM | #26 | |
Drives: 2017 HBM 2LT RS Convertible V6 A8 Join Date: Jan 2018
They are not designed for the short burst of high amperage required by the starter. Deep cycle batteries are designed for lower amperage draw over extended periods of time and can be discharged lower relative to automotive starter batteries, which is normally not a requirement for a car. If you do choose a deep cycle battery with the cranking amps required to use as a starter battery, it will most likely be very large and much more expensive. You may want to research this further before considering it. |
05-25-2020, 07:52 AM | #27 |
When I read All what you write... I start to have some doubt... and maybe thé best way is to unplug thé battery and that a all... just need to settle door windows each time
05-25-2020, 02:10 PM | #28 | |
But still don’t know for the tender... and yes that would be a french one ... |
