06-08-2021, 11:23 PM | #113 |
Drives: 21 camaro rs/lt1 Join Date: Feb 2021
Hey guys i jUst installed an lt2 intake and i have a rotofab cai . Today i went on a friend dyno and wee made 2 runs and on both run the afr was around 12.0 to 12.4 . So it seems that is not lean at all. My friend is the best mustang tuner in my area and not very famliar with gm product but he told me that afr is ok and the stock tune work fine
06-09-2021, 10:12 AM | #114 | |
Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
06-24-2021, 10:58 PM | #115 | |
Hey sorry for the delay but today we put the car on the dyno and we made pass with the stock intake and with the lt2 to compare. I teally dont know whst to think . With the stock intake and rotofab my afr was at 11.9 to 12.2 and with the lt2 it was the samething but the hp gain was incredible. After 2 pass i made 30 more hp and 22 lbs of torque. I think it's high for just an i ntake and a rotofab but the numbers dont lie. Heres the graph with the stock and after with the lt2 https://www.flickr.com/photos/193312...posted-public/ Last edited by phill21; 06-24-2021 at 11:14 PM. |
06-25-2021, 07:25 AM | #116 | |
Drives: 2017 1SS 1LE Join Date: Jun 2016
2017 SS 1LE.
06-25-2021, 08:05 AM | #117 | |
Yes stock throttlebody and not ported lt2 with rotofab dry filter and no tune. Last edited by phill21; 06-25-2021 at 09:42 AM. |
06-25-2021, 09:07 AM | #118 |
Awesome, thanks for posting results!
2017 SS 1LE.
01-16-2022, 06:13 AM | #119 |
Drives: 2022 Chevrolet Camaro LT1 Smurf Join Date: Dec 2020
03-11-2022, 08:30 AM | #120 | |
Drives: Chevrolet Camaro Join Date: Nov 2019
03-21-2022, 12:38 AM | #121 |
Drives: 20’ Chevrolet Camaro 2SS 1LE Join Date: Jan 2009
Nice!
05-25-2022, 01:23 PM | #122 |
Drives: 2019 2SS/1LE Shadow Grey Join Date: Nov 2015
anyone get p0106 code after roto fab and lt2 intake....car dies when hitting the gas hard and shuts the car into reduced power mode...
05-25-2022, 10:31 PM | #123 |
Drives: 21 SS Join Date: Oct 2017
Seems associated with map sensor, make sure connections are tight/plugged in for sensors that you relocated onto lt2.
06-26-2022, 11:24 PM | #124 |
BLUPRINT_1LE
Drives: 2022 Rapid Blue SS 1LE Join Date: May 2017
I just installed my setup today I have a ported LT2 w/ ported 87 throttle body to a 91Mm, rotofab CAI dry with Velossa tech scoop and stock tune and the car is running fine with no issues! I did pulls and definitely can feel the difference. I’m taking the car to the track and see how well it does in a week
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- Last edited by Blackmonba6Gen; 06-27-2022 at 09:05 AM. |
06-27-2022, 06:47 AM | #125 |
I know mine is a little different but I swapped out to a ported Lt2 and stock 95mm, it was very rich on the first logs and lost about 13 rwhp on the very first pull on the dyno. We basically revised the MAP and brought the power back in just a couple pulls plus a little more. I would recommend a tune when you go from the Lt1 to the Lt1 just because you are bringing in more air which is going to require the MAP sensor changes. I don't see why you'd want to change the IM if you don't tune for it. Obviously, mine is a little more modded because of the porting and 95mm TB but save your money if you don't want to make tuning changes.
11-17-2023, 12:32 PM | #126 | |
2021 Camaro 2SS Summit White, Roto-Fab CAI, GPI-LT2 IM, Corsa Extreme+ variable with sec cats delete, Mishimoto catch can.
