09-09-2010, 02:44 PM | #1 |
Camaro Sarah Beth
Drives: 2002 Camaro Convertible Join Date: May 2010
HELP!! 2002 V6 Camaro problems PLEASE HELP!!
I am having issues with my 2002 Camaro it is a V6 and has 143k miles on it :(. When I go to stop the RPMs drop and my car stalls then when I try and start it, it will not start up again. I tried charging the battery with jumper cables, but then I gave up and left it for awhile......then is started up again and is running fine. It has done this twice already. When I try and start it, it acts like it is about to start up but doesn't. I have many guesses to what it could be. Fuel Filter, Fuel Pump, Coil needs replaced, Alternator etc...... Any suggestions or helpful hints will be appreciated. Thanks everyone!!!!
09-09-2010, 03:19 PM | #2 |
Sounds like a clogged fuel line. I had all these signs with my 97 Silverado back in 04 and it turned out that the fuel pump had rusted. I was using octane booster at the time and it knocked off a bunch of rust that clogged the fuel line. It took forever to the start and usually only would if I mashed the gas pedal. Usually garages can check the pressure on the fuel line and determine if this is your problem pretty easily.
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
CAMARO WIKI | Tran | Wiki | 66 | 04-22-2024 11:41 AM |
New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! | RPI Designs | Exterior Parts & Accessories | 30 | 02-20-2013 03:23 PM |
Does the v6 have enough power? | cstproductions | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 305 | 08-29-2012 09:27 PM |
GM unveils Jay Leno Camaro, Camaro Synergy, Camaro Chroma, Camaro Dusk at SEMA | irocnroll | 5th Gen Camaro SS LS LT General Discussions | 101 | 02-27-2012 12:25 PM |
GM memo to dealers | Moose | 5th Gen Camaro SS LS LT General Discussions | 41 | 02-04-2010 07:33 PM |
