02-04-2021, 04:33 AM | #15 |
Drives: 2017 SS 1LE Join Date: Mar 2017
I have the manifold in a box from GPI. Also have a valid HPtuners... Someone can sent me a log file template, I will do it. I have not used HPtuners since 2009, so this is a bit more complex.
I will also log before swap and do compare. |
02-04-2021, 11:10 AM | #16 | |
Drives: 2017 1SS 1LE Join Date: Jun 2016
2017 SS 1LE.
02-04-2021, 01:27 PM | #17 |
Wanna-be motor head.
Drives: 2017 Camaro SS Join Date: Jan 2021
My tuner told me that I would not get the most out of the intake without a tune. Sounds like ya need to tell the computer to make those adjustments.
I would like to ask anyone who has this LT2 Intake Manifold on a convertible - do you just remove the strut tower bar, or should install something else? Thanks. |
02-04-2021, 01:43 PM | #18 | |
Drives: 2018 SS 1LE Join Date: Jan 2020
Also following to see what results are. I'm looking at the GM CAI + MAF calibration, 95mm TB, and LT2 *maybe* to pick up a few hp and driveability without tuning. |
02-04-2021, 05:41 PM | #19 |
Ok guess folks would rather guess
02-04-2021, 08:18 PM | #20 |
Drives: 17 hyper blue 2SS M6 Join Date: Mar 2018
I have the LT2 intake manifold on, and have tracked the car multiple times since.
I did a little adjustment to the tune, but really it didn't require any adjustments up top. My AFR guage is exactly the same as it was before the install. I actually had to make far more adjustments down low, mid rpm level. The adjustments were small, within a range I'm more than comfortable the computer can adjust itself just fine, few percent. Car is cam/heads, and it pulls like crazy up top, the LT2 helps, feels like a noticeable improvement. Obviously it's something you have to be comfortable with, but I wouldn't hesitate to run it without a tune. |
02-05-2021, 10:02 AM | #21 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
03-03-2021, 08:25 PM | #22 |
Drives: 2017 1ss 1le Join Date: Sep 2015
How has nobody taken this offer up?
03-03-2021, 10:34 PM | #23 | |
03-04-2021, 06:58 AM | #24 |
Nope. No takers so I have an order into Pray to dial it in.
