06-21-2019, 09:20 AM | #15 |
Drives: 2018 2ss 1le Join Date: Jan 2018
104 seems really low
are you at altitude... even short shifting 1st you should see at least 107 108 on a bad run..
2018 2ss 1le roto fab dry, Stainless works 1 7/8 lt to 3'" x pipe with highflow cats to stock npp, soler 95mm t/b, edelbrock 2300, LT4 fueling , jms bap and dsx flex fuel, 618/620 on e45 rwhp
Jannetty Motorsports tuned |
06-21-2019, 10:35 AM | #16 |
Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
Your times parallel mine when I had a computer tuning issue. You don't have a GM Performance intake system do you?
104 is very low. I consider 112 low for this car.
06-21-2019, 11:16 PM | #17 |
Drives: 2018 1SS 1LE Join Date: Jan 2019
HouseStark
Original Goodyears. I honestly thought i was around 3,000-3,500, but PDR had at or just below 5,000 at launch. I had a 2004 CTS-V that I let the clutch out at low rpm, then went WOT, it bogged but was consistent...probably slower too because 60' was 2.0 at best, mostly around 2.20 I haven't tried that with the 1LE. Its really hit or miss and takes a lot of passes to get it consistent. I try to shift without lifting, but 1-2 often spins. Its just varies from pass to pass. A8 cars rip off perfect shifts and much easier to launch consistently, so typically a couple tenths quicker. I have 13 passes on 3 visits so far. 7,500 miles on car. |
06-22-2019, 04:46 AM | #18 |
You have an A8, so your car should be roughly 2 tenths quicker than an M6 car. The SS/1LE models have the M6 transmission.
06-22-2019, 07:39 AM | #19 | |
Drives: '18 1SS 1LE Join Date: Sep 2017
Something isn't right.
'18 1SS 1LE Black, PDR
08-08-2019, 01:41 PM | #20 |
Drives: 2018 Camaro SS 1LE Join Date: Sep 2018
08-08-2019, 01:41 PM | #21 |
08-08-2019, 01:45 PM | #22 | |
I did try to do a burn out but got tons of wheel hop. I have no idea how to turn every and all nannies off so that could be why. |
08-08-2019, 02:08 PM | #23 | |
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
If all you want is 0-60 and 1/4 mile runs you're better off with the Auto. If handling and the fun of working a MT appeal to you then the 1LE is head and shoulders above the A8. I grew up on manuals so the M6 is fine for me. The only adjustment I needed to make was to no lift shifting, which is cool as hell. Running an A8 something is definitely wrong with those times. Sub 13 shouldn't be that hard to do. |
08-08-2019, 06:29 PM | #24 | |
08-08-2019, 07:00 PM | #25 |
Two Lane Blacktop
Drives: '18 Camaro 2SS Join Date: Jul 2019
I am actually surprised on some these high 12 / 13 runs. I thought for sure these would get low 12’s..easy.
I had been drag racing my hopped Old Harley the last 3 years, 12.3 @ 106 mph with 1.79 60’s this is with a 97 softail Springer, not exactly a drag bike but I made it one. My Camaro feels ways faster! The test article put them in low 12’s so on paper it’s about as quick with that 455 hp trapping higher. My bike hooks and cooks, I have beat Vrods and big Suzuki’s a few times, just cause it leaves so well and better RT’s Seat of the pants though, this Camaro is a big Rush, nothing like a V8 digging in and ripping off a 1320 foot smile |
08-10-2019, 08:53 AM | #26 |
Drives: like an old lady Join Date: Jun 2012
i think the tach is just that slow in 1st gear. my car does this, as well. the car hooks hard and works great on the street, not so much at the track.
08-10-2019, 04:35 PM | #27 |
It was a very hard thrust that threw me forward a bit. I figured it out it was the no lift shift. In Sport Competitive or Track Race Modes no-lift shift engages. When you traditionally shift while no lift shift is engaged boom it happens. Feels just like a hard fuel cut off at like 6200 rpm.
08-11-2019, 07:16 PM | #28 |
Two Lane Blacktop
I took my 2SS to the test and tune today first time in this car.
Just for comparison first run sport mode in Drive everything else on, just mashing the pedal 12.77 @115 Sport mode, paddle shift everything on, again mashing 12.57@110 |
