Old 06-17-2019, 03:12 PM   #1
Katech_Zach
Katech_Zach's Avatar
Drives: 14 Camaro SS 1LE
Katech Stage 5 ZL1 1LE SN# 06
One of the more recent cars to roll into our shop was this Summit White 2018 ZL1 1LE. The owner originally upgraded to our LT4 Stage 4 package and decided that he wanted even more power. We gave him just that, and upgraded him to our Stage 5 kit. The car now makes 859whp and 792ft/lbs.
Stage 5 E85: 859whp, 792ft/lbs
Stage 4 E85: 702whp, 657ft/lbs
Stock 93: 540whp, 502ft/lbs
Katech_Zach is offline   Reply With Quote
Old 06-17-2019, 11:25 PM   #2
Uncle Sam
Drives: 2017 Camaro 1LE Hyper Blue
It's never enough.
Uncle Sam is offline   Reply With Quote
Old 06-18-2019, 07:50 AM   #3
Katech_Zach
Originally Posted by Uncle Sam View Post
It's never enough.
Very true statement. The car is surprisingly tame for the power it makes though.
Old 06-18-2019, 08:14 AM   #4
Uncle Sam
Amazing performance times we live in. A couple of questions for you:
1. Do you think this Stage 5 859 RWHP would be over 1000 HP at the crank?
2. Where is the weak point in the Camaro when HP goes up? Engine internals? Clutch/transmission? Half shafts? Cooling?
Just asking because of a love for cars.
I am one lottery ticket away from your door!
Old 06-18-2019, 10:01 AM   #5
RyanR3KC
"1/LE Rebel Alliance"
RyanR3KC's Avatar
Drives: 18 Black 1SS 1LE “Siouxsie
Would love to see how this does on a Road Course.
It seems the Alpha chassis can hold a lot of power
RyanR3KC is offline   Reply With Quote
Old 06-18-2019, 11:36 AM   #6
Katech_Zach
I am one lottery ticket away from you door!
1) This would be a 1000 hp engine at the crank
2) I am not as familiar with the Alpha chassis, I currently own a 5th gen. What I do know is that the 6th gen is levels above the 5th gens as far as structure and engineering goes. If I were to pick a "weak point", it would be the LT1 rotating assembly. The LT4 is great on the other hand.
It will be sweet to see on the track. The Alpha chassis can put down a lot more power than the previous generation Camaro assuming it is set up right.
Old 06-18-2019, 01:45 PM   #7
Matos1LE
Drives: SS 1LE
I heard the LT4s were having crank issues? One of my autocross buddies had his Z06 at the dealer for a bad crank and he found on the forums that it was pretty common.
Matos1LE is offline   Reply With Quote
Old 06-19-2019, 05:59 AM   #8
Infamus
Infamus's Avatar
Drives: 2018 Camaro ZL1
That is awesome!
2018 ZL1 - Daily driver
2018 Mercedes Benz AMG GTS
2017 C7 Grand Sport - Stage two Edelbrock
Infamus is offline   Reply With Quote
Old 06-19-2019, 08:14 AM   #9
Katech_Zach
There was a recall on the cranks if they were measured to have excessive crank end play. Our experience with them has been good so far with no major concerns.
Originally Posted by Infamus View Post
That is awesome!
It'll only get better once the 2650's start to hit the shop.
