12-07-2018, 01:14 PM | #1 |
Drives: 2018 1ss 1LE Join Date: Aug 2018
305/35/20 QUESTIONS
Hey guys i have a 2018 SS 1LE currently running the stock size 285/30/20 in front and 305/30/20 in the rear. Thinking about going with 35 profile all around. I do have the eibach pro kit lowering springs on the car. Just wanted to know if anyone has ran this set up and if there is any rubbing?
12-07-2018, 01:40 PM | #2 |
yes you will rub and you need to relocate the wiring harness
12-10-2018, 02:15 PM | #3 |
Drives: ISO ss 1le Join Date: May 2018
You will also rub the front lower spring perch with a 35 series tire.
12-10-2018, 03:09 PM | #4 |
I see that all my buddys with 1LE models that are lowered dont have any issues. Are the 1LE models that much different then the standard SS
12-10-2018, 03:50 PM | #5 | |
Yes, the 1LE perches come out a bit futher. Go look at your stock 285/30 and check how close you already are to the spring perch, then add 15mm to the top of the tire, it will definitely hit. It doesn't really change anything that you're lowered as that doesn't change the spring perch height, just brings the body closer to the wheel. Do "all your buddys that are lowered" have 6th gen 1LE's? The stock tire size on 5th gen is a 285/35/20. |
12-10-2018, 04:04 PM | #6 |
All are 6th gen camaros
12-11-2018, 06:59 AM | #7 |
I hope this is not the case, have a 18 ZL1 and just ordered 305/35r20 and 285/35r20 all season for the car. I will run it out to see if there is any rub issue. Moved rear wire harness as a safe guard.
12-11-2018, 09:26 AM | #8 |
You’ll probably run into issues regarding the front spring perch. With the 285/30/20 we are about 11 mm from the perch, and a 285/35/20 is 15mm taller than a 285/30/20
12-13-2018, 04:03 AM | #9 |
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
Tagged for VADERZL1's results.
12-13-2018, 04:52 AM | #10 | |
Drives: 1SS 1LE Join Date: Mar 2018
I believe there are a couple of people that posted on this forum that they tried those sizes and they had the rub. Could've sworn someone posted with pictures as well. I will dig deeper into this now..
What this car really needs is a notification eliminator. There's a wi-fi notification. Bluetooth notification. Parking brake disabled notification. Always some annoying notification popping up. - Navigator post
12-13-2018, 06:19 AM | #11 |
Vader may not have problems with the front since he’s got a zl1 1LE and the spring perch is much smaller. However a 285/35/20 is nearly a 28” tire and the stock 305/30/19 is a 26.2” tire. That’s gonna rub somewhere.
12-18-2018, 06:32 AM | #12 |
Change to 35 profile resulted in no issues. Installed 285/35/20 and 305/35/20 BFG Comp2 All Season. After 250 miles in all conditions, no rub & no interference. Not even close to rear wire harness (although I relocated as safe guard), still tight pinky finger between front and strut flange. Really cushioned up the ride and lateral grip is very good in 17 degree and 40 degree wet. Put it in Weather mode and gave it heck, very impressed. All four mounted and balanced run about $850
Again, this is on the ZL1 regular, not a 1LE version Last edited by VADERZL1; 12-18-2018 at 06:33 AM. Reason: typo |
12-18-2018, 10:07 AM | #13 | |
12-18-2018, 11:10 AM | #14 | |
