11-24-2019, 07:20 PM | #1 |
Drives: 2018 Camaro ZL1 1LE Join Date: Nov 2019
Whipple 2.9 New $5,000.00
ZL1 LT4 17-18 Whipple Supercharger 2.9L $5,000.00 NEW
Comes with ACDelco 12678223 GM Original Equipment Fuel Injection Throttle Body Assembly with Sensor (Takeoff) This was only mounted on the engine and is not big enough for my requirments. W175AX 2.9L supercharger head unit, black finish standard This unit is totally complete. Never been on the dyno. Zero Miles John 775-505-4114 Last edited by johnl; 11-24-2019 at 07:50 PM. Reason: add number |
11-24-2019, 08:52 PM | #2 |
Drives: Chevy Camaro Join Date: Jul 2019
Just the SC not pump, lines or the rest of the kit?
11-25-2019, 06:43 AM | #3 |
He’s selling the LT4 version, which I believe reuses the stock ZL1 pump/lines/cooler. The LT1 kit comes with all that stuff and uses a different pulley setup (10 rib) if I’m not mistaken.
11-25-2019, 11:03 AM | #4 |
Whipple 2.9 comes complete as purcahsed from Whipple
The whipple 2.9 is a complete kit as purchased from Whipple. The LT4 6.2 liter engine using the OEM existing pump and air exchanger. This has a brand gates green belt 8 rib. All the pulleys that come with the whipple supercharger will be included. There are NO missing parts.
