Old 05-21-2020, 07:19 AM   #1
Robby23
Drives: 2018 1SS M6
Cowl replacement?
so looking at doing the hi-ram. I understand you have to cut the cowl some. Was wondering if that cowl piece is replaceable? looking at this pic it looks like you can just bolt a new one on if needed. anyone able to confirm this?
2018 1SS M6 - OTR intake, HI Ram intake, Ceramic Coated TSP Headers Catless, AWE Touring Axle-Back, Flex Fuel, Pray Performace stage 3 cam, TSP ported heads, Pray Ported 95MM TB and Ported HI-RAM. SJM Line-Lock. F14 Drag Pack 17's with front skinnies. Tuned by Pray Performance.
Robby23 is offline   Reply With Quote
Old 05-21-2020, 08:34 AM   #2
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
Unless I am mistaken your pic looks like a V6 part.
The part u are interested in is Plenum Panel - GM (84261404)
It’s around $385 plus install from a body shop. You probably could just drill out spot welds and just get someone to weld it in if your not handy with welding. The GM bonding glue for panels would probably work for that part.
I installed a high Ram in my 2016 with notching our a piece of the tin. Just take off the plastic cowl first. Anything can almost basically can be restored back to stock with parts.
I just added a small brace to support missing tin but probably not needed. I also added a rubber weather strip to hide my cut into cowl and probably isn’t needed if you do a nice cut. Good luck on your project and just take your time and don’t be rushed if your doing most of the work yourself.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
