12-16-2016, 10:03 PM | #1 |
H-Town Camaro Club
Drives: 2010 ABM 1SS/RS, Red 85 Z28 Join Date: Feb 2013
Need help with torque specs
All right guys I know this isn't the transmission section, but I have also posted there too. A lot of you guys know that I've bent some rods in my engine well I have it back and I'm ready to put it in this weekend but I cannot find the instruction for my RPS/Street slayer clutch, I have the triple disc, if anyone could please give me the torque specs for the flywheel bolts as well as the clutch pressure plate housing I would greatly appreciate it, I want to see if I can get this thing running by Sunday, thanks in advance.
AGP Twin Turbo, RPS Triple Carbon Clutch, ZL1 Diff with 3.73 gears and Kooks 3" Stainless Steel Exhaust with X Crossover, Kooks Stainless Steel Mufflers, Go Fast Bits EBC, AEM Methanol injection and AEM gauges UEGO and Fuel pressure, Livernois's dual fuel pump, KB Boost a Pump, AUS 1000cc injectors, Full BMR suspension with Koni shocks, JDP Color Changing Halos, Color Changing Scanner Light Bar and Rockford Fosgate T Series Amp's Kicker L7 Sub's.
Build Thread: http://www.camaro5.com/forums/showthread.php?t=400372 |
12-16-2016, 10:41 PM | #2 |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
Here try this.
****EDIT**** Sorry I linked the wrong tech manual.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 Last edited by 1KillerSS; 12-16-2016 at 10:54 PM. |
12-16-2016, 10:57 PM | #3 |
Flywheel Bolts - First Pass 20 N.m 15 lb ft
Flywheel Bolts - Second Pass 50 N.m 37 lb ft Flywheel Bolts - Final Pass 100 N.m 74 lb ft Clutch Pressure Plate Bolts 70 N.m 52 lb ft
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
12-16-2016, 11:58 PM | #4 |
H-Town Camaro Club
Thanks Jeff, but I have the stock torque specifications. I'm thinking you may be right on the flywheel bolts, but I have the RPS/street slayer clutch, and I need to know what the torque is for the pressure plate bolts mine is the billet aluminum one. But thanks your help is always appreciated.
12-17-2016, 05:38 AM | #5 |
Drives: it changes Join Date: Nov 2010
What size/type are the fasteners. Almost all torque settings go by this.
12-17-2016, 07:10 AM | #6 |
Drives: 2009 ZR1 Join Date: May 2010
They're like 25lbs or so.... I'd wait and call RPS and ask them.
12-17-2016, 07:40 AM | #7 |
Drives: 2006 Z06 Join Date: Oct 2010
Call RPS.
Just put my mantic in last night, and it was 35NM for the pressure plate.
Nick
Corvette Z06 -1200ish rwhp |
12-17-2016, 01:55 PM | #8 | |
H-Town Camaro Club
Just put my mantic in last night, and it was 35NM for the pressure plate. __________________ Nick Sorry Stevie if you put a link and it didn't come through, thanks for the help guys I didn't know RPS would be open the day I'll give them a shot, just getting back home.
12-17-2016, 01:57 PM | #9 |
Strange echo in here.
05-27-2020, 07:42 AM | #10 |
Drives: Bumblebee Join Date: Mar 2014
What about LLT 3.6L V6?
Camaro LT2 RS
Transformers package Airlift bagged 22" Rohana RC22 BMW 325i Convertible |
