12-12-2022, 07:59 AM | #29 | |
376 cubic inches of fun
12-12-2022, 11:26 AM | #30 |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
Again You are talking 2 Different Different Brakes
The Sliding Calipers do not require to replace the Sliding Pins If for some unknown you remove the Bracket that the SLIDING CALIPERS Bolt to then Yes you would replace the Bolts The only reason to remove the Caliper Brackets would be to turn the Rotors. Most V6 owners are going to just replace just the brakes
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
12-12-2022, 11:28 AM | #31 | |
Again a V8 guy trying to tell someone who owns a V6 what to do
12-12-2022, 01:16 PM | #32 | |
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
Front Brake Caliper Hardware Replacement (LLT) Removal Procedure Warning: Refer to Brake Dust Warning. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle. Remove the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation. Object ID: 2201918Click here for detailed picture of the image. Note: The brake caliper guide pin bolts must be replaced any time they are removed. Do not reuse the brake caliper guide pin bolts. |
12-12-2022, 01:44 PM | #33 |
clicky no workee.so this means the bolts that hold the caliper bracket to the car should be replaced and the bolts that hold the caliper to the bracket are ok to reuse? not trying to give you a hard time,i just want my brakes to be safe.or should all these bolts be replaced...who had the bright idea of torque to yeild bolts in something that will be removed and replaced several times during ownership anyway?
12-12-2022, 02:24 PM | #34 | |
12-12-2022, 02:49 PM | #35 | |
12-12-2022, 02:57 PM | #36 |
It don’t come easy.
Ordered my replacement bolts today from the dealer. About $6 a pop. No biggie. After reusing mine and doing the TTY / TTA as Not A 45 stated above, I feel they’re probably now overstretched, as it were.
12-12-2022, 04:04 PM | #37 | |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Which begs the question, if TTY is such a great idea, why do all the racers use ARP? They beat on their stuff more than anyone.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
12-12-2022, 04:27 PM | #38 | |
12-12-2022, 09:21 PM | #39 |
12-12-2022, 09:36 PM | #40 |
but at the same time where i got my info From
This was From a Chiltons 2010 -2015 Repair Manual
12-13-2022, 09:51 AM | #41 | |
12-13-2022, 10:12 AM | #42 |
It don’t come easy.
Picked up the bolts today and confirmed through two gm mechanics that there are, in fact, TTY bolts. Asked if they ever reuse them… got the side glance look and a smile.
Btw, no Loctite on the threads. My thinking is the same as Not A 45, once stretched, don’t do the to 90 degrees thing. For what’s it’s worth, I’m replacing mine because, as I stated above, I went to 90 on them and I feel that’s too much stretch, for used bolts. Hope this info didn’t go to far off from your topic, redcoats1976.
