08-17-2022, 08:06 PM | #15 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
Imagine something like .010-.040 runout here by the time it gets to the greater diameter of the tire. (this is NOT a Camaro)
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
08-17-2022, 08:07 PM | #16 | |
Drives: 15SS Camaro Join Date: Dec 2020
08-17-2022, 08:39 PM | #17 |
Drives: 2013 1ss Join Date: Jul 2012
The tire had excessive runout or out of round. I had other issues too but this was an easy check at a shop.
08-17-2022, 08:44 PM | #18 |
You should try different conditions which may help narrow it down. Does vibration change if you hold speed while stepping on brakes. Does it change if going around a curve. Does it change if applying emergency brake while holding speed? Does intensity increase with speed?
08-17-2022, 09:39 PM | #19 |
I don't want to insult anyone's intelligence but this is what I mean if the hub is bent. It was hit by a semi after all.The farther from the bend the greater the distance from the vertical axis.
08-18-2022, 02:27 AM | #20 |
im thinking your theory is good.have an appointment at firestone tomorrow to have the 3 tires i bought checked for balance at the body shops request,at which time im going to ask if they can run it up to 75 mph on the rack.if its the drivers rear tire/wheel/hub as i suspect that should show up then.
08-18-2022, 06:35 AM | #21 |
Drives: 2014 1ss camaro Join Date: Jul 2017
tire guy told once that a half ounce of weight could cause vibration. if your vibration is confined to one wheel swap it with another on your car and see if the vibration changes location. that is if you have a square set up.
08-18-2022, 07:15 AM | #22 | |
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
Also I want to caution you that if it was hit hard enough to damage the wheel you can bet your ass in about 6 months or so that left rear hub bearing is going to be making noise. I would insist with the insurance adjuster that that hub be replaced. |
08-18-2022, 07:32 AM | #23 |
A wise man, that tire guy. ONE OUNCE of weight located 7.5" (radius) from centerline (15" diameter wheel) produces 100LBS of force at 1000RPM. More on a 20" wheel. (I wrote a driveshaft balance program years ago and it only goes to 15" dia)
08-18-2022, 03:52 PM | #24 | |
It don’t come easy.
08-19-2022, 10:48 AM | #25 |
took it to firestone,who checked all wheels for runout,suspension and hubs for the princely sum of 10 bucks,as well as rebalancing all wheels,i bet you cant guess which wheel and tire were not balanced correctly.had it up to 90,,,smooth as silk.
08-19-2022, 12:01 PM | #26 |
The one that got punched by the semi? Or…ALL of them!
08-19-2022, 02:09 PM | #27 |
it was the one that got semi-punched,actually its replacement.brand new OEM wheel,new tire installed by the chevy dealer...but yet they couldnt care to balance it right.then the service rep said to have the other 3 ( had all 3 new tires installed and balanced at firestone) checked because chevy would charge me to check them.i guess i should be glad i did.,..it would suck to pay chevy a lot more to do it incorrectly.our local firestone has been pretty good over the years.the old rim and tire were only good for the aluminum,big chunks just gone.
08-19-2022, 08:32 PM | #28 | |
Glad you got it sorted out!
