09-13-2022, 06:20 AM | #29 | |
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
09-13-2022, 08:00 AM | #30 |
It don’t come easy.
Is it true that the sensors have to be woken up from sleep by the wheel movement? Think this would be another reason why the sensors don’t stay connected when trying this tube method.
09-13-2022, 09:12 AM | #31 | |
or so the rcdlr updates the pressure without the car being moved. I will have to check on that. |
09-13-2022, 09:15 AM | #32 | |
When the vehicle is stationary, the sensors internal shock sensor is inactive which puts the sensors into a Stationary state. In this state the sensors sample tire pressure once every 30 sec and do not transmit at all if the tire pressure does not change. As vehicle speed increases, the shock sensor pulses every wheel rotation, which puts the sensor into Rolling mode. The remote control door lock receiver receives and then sends the tire pressure and temperature data to the body control module (BCM). The BCM translates the data contained in the tire pressure sensor radio frequency transmissions into sensor presence, sensor mode, and tire pressure. Once vehicle speed is greater than 40 km/h (25 MPH), the sensors begin to transmit once a minute keeping the pressure data up to date. |
09-13-2022, 09:41 AM | #33 |
Drives: 2017 2SS Arctic blue fully loaded Join Date: Mar 2021
correct. in fact i had to pump all my tyres up the other day. took about 5 minutes of driving to update the pressure info.
09-14-2022, 07:37 PM | #34 |
Drives: 15SS Camaro Join Date: Dec 2020
Like I said I never tried it so don't know if it will work, sounds like it won't.
12-19-2022, 10:13 PM | #35 | |
Drives: Firebird 95, Equinox 05, Camaro 2SS Join Date: Aug 2009
Great heads-up... Than you!
Your comment is great advice. Thanks!
12-20-2022, 09:11 PM | #36 |
I believe what they did was program them then put them in the pressure vessel together. They claimed it worked fine. Its been a while since I ran across it so I'm not sure where I seen it. I'm going to be trying this when mine stop working. Things are just getting out of hand expensive to get even the basics done on a car anymore. Personlly I may jusy say hell with it and push the little button every time I use the car. The led doesn't bother me because I can't even see it anymore! HA (i have in the past took the cluster out and made the bothersome led's go to sleep permanently.
