Old 02-26-2020, 08:15 PM   #1
Tyestick
Tyestick's Avatar
Drives: 19’ Camaro SS 1LE
Exclamation Burnt intake valve... 2019 1LE
Car has 13,xxx miles.
Was experiencing some issues with the 1LE...
Rough idle, check engine light, forcing me out of active rev match...
‘Service rear axle/stabilitrack’ kept popping up, along with the other issues mentioned above.
Dealership initially thought it was due to bad injectors, and replaced a few of those, and cleaned the spark plugs.
Issues resurfaced the next day.
Stopped by the shop today to get an update, and was told that my intake valve was burnt.
How common is this issue, and what would cause this?
2019 Camaro SS 1LE
Tyestick is offline   Reply With Quote
Old 02-26-2020, 09:00 PM   #2
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Was the fuel injector replaced on the same cylinder as the burnt valve?
Old 02-26-2020, 09:14 PM   #3
Dixie ZL1
NOXQCES ZL1
Drives: 2017 Camaro ZL1
Unless I’m lot seeing something....That intake valve isn’t burnt. It isn’t closing due to carbon buildup.
Dixie ZL1 is offline   Reply With Quote
Old 02-26-2020, 09:31 PM   #4
Tyestick
Tyestick's Avatar
I can’t remember offhand. I’ll check the paperwork when I get home later tonight.
It’s possible. I’m just going off the information I was told...
2019 Camaro SS 1LE
Old 02-27-2020, 09:01 AM   #5
TJay74
Yep, that is the downside to DI. That is carbon coking and if 1 intake valve has it, several others have it as well.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
Old 02-27-2020, 10:59 AM   #6
JROC
Drives: 19 Camaro SS 1LE, 03 Ford Lightning
Dual injection FTW.
JROC is offline   Reply With Quote
Old 02-27-2020, 11:18 AM   #7
crab
crab's Avatar
Drives: 2019 1LE
Originally Posted by JROC View Post
Dual injection FTW.
Yea like LT5
"That my friend.. is the sweet succulent sound of the car preparing to ignite the wonderfully tasty nectar your V8 needs to send the screaming bald eagles furiously from the 4 pipes out of the rear of your vehicle"
crab is offline   Reply With Quote
Old 02-27-2020, 11:34 AM   #8
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
lol jesus christ hope you not putting 87 in that poor car haha
Old 02-27-2020, 01:50 PM   #9
GTSLOW
Daily Driven 1LE
GTSLOW's Avatar
Drives: 2018 1SS 1LE
"How common is this issue." Well as far as I know you're patient #1.
2018 1SS 1LE
GTSLOW is offline   Reply With Quote
Old 02-27-2020, 10:09 PM   #10
JROC
Originally Posted by crab View Post
Yea like LT5
I didn't know LT5 had dual injection. Very cool. I wonder if the LT2 will get it as well?
I haven't heard about as many issues with it on GM's as brands like BMW and Ford, but it is an 8issue associated with DI motors.
A motor with port injection washes off the back of the intake valve. When you go DI your not washing off the back of the valves. Dual injection uses both direct and port injection. You get the benefits of both and they cancel out each others negatives. I believe Toyota came up with the idea. Ford seems to have seen the most success or benefits from it. Motors like the pre-17 Ecoboost V6's and a few other DI Fords had back carbon buildup issues. When Ford came out with the GEN3 Coyote for the 2018 model year they went straight from port injection to dual injection to combat the issue before it became one.
Old 02-28-2020, 06:31 AM   #11
MrChrisLS3
Drives: 2018 1SS M6
I know on the LT5 the dual injection kicks in at WOT, or near it. The reasoning was getting enough fuel for the larger S/C.
As far as the valve, maybe the valve itself was faulty. The other thing I can think of is if the valve seat is off, or if there is an issue with the manifold seal on that cylinder causing unmetered air in the chamber, making that cylinder run lean?
MrChrisLS3 is offline   Reply With Quote
Old 02-28-2020, 06:53 AM   #12
MMGrnvl
Drives: 2018 ZL1 White
What fuel are you using? Thats way too much buildup for 13K miles.
MMGrnvl is offline   Reply With Quote
Old 02-28-2020, 08:13 AM   #13
JROC
I wonder if you could spray some SeaFoam or something similar into the intake track every so often to clean the valves? Get the motor up to temperture and spray into the TB or something.
With these modern, higher-compression cars with sensitive electronics is SeaForm would be good to use on them or not? Still it would just be like spraying some very high octane into the cylinder so I don't see where it could really hurt the car.
Old 02-28-2020, 08:37 AM   #14
L78toLT1
L78toLT1's Avatar
That's not really excessive on these motors. Here's mine at 16k
Baby Blue
