07-10-2017, 04:16 AM | #1 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
thoughts on swapping to powerglide
like the title says. I'm tossing around the idea of swapping to a glide. will most likely be a bte with a 1.69 or 1.80 straight cut gearset. I will be swapping to a 3.23 rear over the current 3.73 rear end as well.
the reason for thiking this is I would be having the car caged very soon( getting quotes right now) and adding a parachute in prep for being legal. I anticipate the car to trap 155-160 range. big cubic inch, big turbo(s) undecided on all of that at this moment in time... thoughts?
12 camaro ss 427lsx, th400, f310 heads, crower shaft mounts, gpi specd solid roller, shearerfab 2k hp a/w, twin bullseye 88mm turbos, hughes pro ssx bolt together converter, holley dominator, 8.50 cert, backhalf, Ford 9", 33x17x16 tires, c16 fuel
07-10-2017, 09:43 AM | #2 |
Drives: 2011 Camaro 2SS Join Date: Sep 2015
Do it, you wont regret it. boost + 2 speed auto, the car should fly.
Just remember go to with an aftermarket case for the trans That's the same direction I am going towards since my rpm built 6 speed trans is starting to give out on me |
07-10-2017, 11:16 AM | #3 |
LVL 50 Troll Stomper
Drives: 2010 Camaro Join Date: Feb 2008
I like my th400 but I don't think you could go wrong with a glide either
07-10-2017, 12:48 PM | #4 |
Drives: 2009 ZR1 Join Date: May 2010
Do it.
Something happened the other night while datalogging to my car. I think the clutch let go (Triple RPS-no crunchy noises anywhere. Engine just revs and there is an occasional metal on metal squeal from the clutch/front of trans area) I've got other things going on so I haven't taken the trans out yet. When I figure out what the deal is, I'm going to decide whether to rebuild the clutch/trans or auto swap to a 4L80 or TH400. Trans is already a Lvl 6 RPM. |
07-10-2017, 01:18 PM | #5 |
yes! I'm looking at the bte racing powerglide, it's 2400hp rated and not badly priced. I don't think I'll have any issue getting rid of my 4l80 stuff
07-10-2017, 01:22 PM | #6 |
07-10-2017, 02:03 PM | #7 |
Drives: T Join Date: Mar 2015
Jakes 4l80 i hear is one of the best and a great value. If my trans pops thats what im throwing in with a 3200+ stall.
07-10-2017, 03:20 PM | #8 |
that's what I'm running, their stage 3 trans
07-10-2017, 04:44 PM | #9 |
Svt lol
Drives: 2011 ss inferno orange blown Join Date: Jan 2012
Why not a th400 if my 4l80 fails that's what I'm swapping to. They're cheap and very durable plus you'll enjoy that extra gear.
plasti dip is not a mod.......and a cold air intake doesn't make you fast!
07-10-2017, 04:48 PM | #10 |
weight and at that power level there's no need for the extra gear really. lots of guys are picking up et with a glide over a 4l80/th400 in strictly drag form.
Thread Tools | |
