06-14-2019, 12:56 PM | #1 |
Drives: 2018 Camaro LS / 2018 Equinox LS Join Date: Mar 2019
Accidently attempted to put the car in reverse without clutch pressed
My car was in neutral at full stop. I didn't realize I didnt have the clutch pressed and i tried to put the car in to reverse. It went passed the gate but wouldnt go in to reverse until I realized i didnt have the clutch pressed. No wierd noise or vibration. Could something like this damage the transmission?
06-14-2019, 01:04 PM | #2 |
Drives: '17 Red Hot 2SS 6MT Join Date: Mar 2018
There is a lockout solenoid on reverse. It won't let you into reverse while the car is moving forward, so it's possible that it's also active if the clutch is not depressed. No noise/grinding then no worries.
06-14-2019, 01:05 PM | #3 |
ZYJ
Drives: 2017 1SS Camaro/6 speed Join Date: Sep 2014
No damage unless you were really hard on it. But nothing I will worried about it.
06-14-2019, 01:06 PM | #4 |
thank you sir
06-14-2019, 03:03 PM | #5 |
Drives: Camaro 50th anniversary edition Join Date: May 2017
Don’t worry, nothing happened as long as you didn’t force it too much. Even than if you have your foot on the brake the car will just stall.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
06-14-2019, 03:18 PM | #6 |
No harm to your Camaro. Rest easy!
Thread Tools | |
