09-20-2012, 10:54 AM | #1 |
Drives: One of the rare ABM camaros Join Date: Apr 2009
Smallest pulley on Eforce with stock everything else
Just a quick question. What is the smallest pulley you can run on the eforce for an M6. Here are the parameters:
Stock intake and exhaust 52 lb injectors that come in the kit 91 octane fuel thanks Dean
2000 5/23 3000 5/27 3400 6/20 TPW of 6/29 3800 7/3 4D00 7/8 interned at QC 4B00 7/16 Released from QC 4200 7/20 8/5 We picked up the car |
09-20-2012, 01:05 PM | #2 |
Drives: 700 rwhp 2010 SS Join Date: Sep 2010
The one it comes with.
09-20-2012, 07:18 PM | #3 |
I am thinking you can put one smaller than a 3.5 on with the right tune. Ultimately looking to see at what point I would need bigger injectors. Is it a 3.25 pulley?
Dean
09-20-2012, 07:26 PM | #4 |
Drives: 2010 AquaBlue 2SS/RS Join Date: Sep 2009
I agree with Oxtar. Your injectors are probly maxed now
09-20-2012, 07:31 PM | #5 |
I went 3.25 with 65# injectors.
Oh, and a boost-a-pump.
2010 2SS/RS RJT, ADM CAI, Borla Shorties, Borla "S" Cat Back, Edelbrock E-Force Supercharger, GMS Wires, GMS Rear Trailing Arms, GMS Rotors, GMS End Links, GMS Tunnel Brace, GMS Rear Tie Rods, GMS 1G Suspension Package, GMS Stage 3 CNC ported heads, GMS Spec'd R12 Custom Ground Camshaft, Snow Meth Injection, GMS Custom Tuned, Norris Catch Can, MTI Brake Lines, Pfadt Coilovers, Sway Bars, Camber Kit, and Rear LCA Reinforcement, , AAC Footwell, Trunk, DRL and Dome LED Lighting, Technostalgia Tail Lights, RED B/A Pedals, Kompression Custom Wheels with Nitto tires, 621RWHP/584RWTQ
09-20-2012, 07:42 PM | #6 | |
smaller pulley same injectors?...No supporting mods.......
09-20-2012, 07:48 PM | #7 | |
Long Tube Headers JRE fuel line upgrade LPE Twin Pumps ID-850 injectors ZR-1 Plugs JRE tune 3.25 Pulley Ted.
www.jannettyracing.com
09-20-2012, 08:30 PM | #8 |
Would love to go Long Tube. Gotta live in Ca though. This sounds killer, if you can swing it I would do this.
09-20-2012, 08:41 PM | #9 |
funny.
I guess it is 3.5 then. Living in Cali means no long tubes. Dean
09-20-2012, 09:31 PM | #10 | |
I love that rough idle blower cam!
09-21-2012, 08:11 AM | #11 |
Yeah, he was looking for stage 2 the JRE Blower Cam is stage 3
09-21-2012, 12:01 PM | #12 |
Just re-name it stage badass instead of stage 3
09-21-2012, 12:05 PM | #13 |
I just bought a 3" pulley and a ZL1 Fuel pump I got 60lb injectors I'm getting everything put in this spring..
09-21-2012, 01:38 PM | #14 |
Ted,
What kind of RWHP could you get with adding the bigger injectors, BAP, plugs, and smaller pulley. Long tubes are out. If it helps I am running the JBA shorties and a 3" exhaust, but still running thru factory cats so I can pass smog. Dean
